Using Stealth Diff Halves In A&L Lethal Weapon
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
I figured I'd start this thread to help people with their LW tranny.
These pics and info were sent to me through e-mails from Daryl of Factory Works after I ordered a Lethal Weapon tranny kit without the proper diff halves because they're no longer available.
It requires a 1/8" ID X .160" (5mm) OD X .115" long tube spacer. This lets the LW's diff ride on the Stealth's 1/8" center diff shaft.
I was lucky enough to find some brass pieces in an old parts box that fit perfectly for my 10T shelfer with a LW tranny.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Using Stealth Diff Halves In A&L Lethal Weapon
Post by Lonestar »
awesome! thanks :)
Paul
wyldbill
Post by wyldbill »
awesome that helps a ton.
now i just need to find a spacer, any idea where yours came from?
i think the diff in the picture is missing a few balls. although i have done that a few times in my oval rides to save on weight run 6 instead of 12.
what size is the bearing in the diff pulley? ID/OD?
LTO_Dave
Post by LTO_Dave »
wyldbill wrote:awesome that helps a ton.
I honestly have no idea what it's for. I got a small parts box in an ebay lot a few years ago and it was in there. Daryl said he might machine some spacers, but I've never asked him if he's had time to.
jwscab wrote:what size is the bearing in the diff pulley? ID/OD?
It's a 5mm x 11mm x 3mm unflanged bearing. The instructions say it's special for this gear.
The magical piece would be a 1/8" x 11mm x 3mm bearing, which I haven't been able to find yet.
ugh....11mm. yeah it's not a common bearing. 11mm is really close to 7/16", so if you could find a cheap 1/8" x7/16" bearing it might also work.
that brass sleeve sorta reminds me of a piece for tamiya cars and trucks; a shock end bushing.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
That's awesome!!! Thanks for the great info!
