new to owning an rc10t
vaughan3320
Post by vaughan3320 »
just wandering what is the best and easiest way to convert the original rims to the newer style rims & wheels. any other good upgrades would also be welcomed. thank you and glad to join the group. :D
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: new to owning an rc10t
Post by klavy69 »
what do you mean by the newer style? Are you talking quick change rears or rulux or ? Or are you asking about 3/16" vs. 1/4" rears? Just a quick bearing and axle change in the rear is all you need to change axle sizes depending on if you have cvds or dogbones. All newer wheels have the same offset as the older ones. Fronts are same so nothing needs to be done. If you are talking about quick change rears that involves a lil more parts but not much. Let us know and I'm sure someone can help...
vaughan3320
sorry about that we are talking about installing 3/16 cvds. and installing newer style 2.2 rims. or is there an easier way to convert the 1/4 dogbones and run 2.2 rims. and then what would i do in the front? change spindles out or just bearing replacement and newer rims? thanks for the help :?:
klavy69
Moderator
Post by klavy69 »
best way to do it is pretty much like you said. Drop in some cvds in the rear with 3/16" axles plus the needed bearings and front you just need bearings if you don't allready have them and newer rims. Offset are all the same as long as you are using AE wheels or wheels meant for AE.
vaughan3320
that sounds great :D do you happen to know what size bearings go in the front thanks for the help.
klavy69
Moderator
Post by klavy69 »
3/16 x 3/8
vaughan3320
thankyou :D
vintage-tman
Post by vintage-tman »
its simple haha not really :lol: but convert your axels to 3/16 change the bearings to 3/16x3/8 and buy the t4 rims and any 2.2 truck tire rims and u will be able to run modern rims and tires i hopw this helps
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 23 guests
