Has anybody put the posi lock GT2/T4 system on a 10T will it fit ?
Thanks
Quick question
Quick question
Vintage rides: Worlds car, RC10T, RC10GT, XX, Rally Weapon
Current rides: B5M CE, T5M, SC5, MBX7, MBX6-T, 8IGHT 2.0, K1
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: Quick question
Yup, lowrydesigns did it with some GT2 parts, the GT2 CVA bones are shorter than the T4.1 bones and I believe he used RPM large bearing rear hubs. The front was just a swap to drilled out T4.1 caster blocks and the posi lock.front spindles.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Quick question
His truck is in the f/s section here:
http://www.rc10talk.com/viewtopic.php?f=6&t=22052
but you have to have access to the b/s/t area to see it. From his description here are a few lines of what it has.
But mostly like Reggie said...it can be done. Its a beautiful truck and wish I could validate the money for it for myself.rpm black body mounts
rpm 2.6:1 trans conversion w/t4 shaft and trinity light weight t4 slipper pads
rpm t4 gear cover
rpm rc10t arms
rpm black rod ends
rpm shock cups
rpm rear arm mounts
lunsford turnbuckles w/ rpm cups and all newer style assoc ball studs
t4 front c-hubs and in line axles
t4 rear hubs and cvas w/ gt2 quick change hubs
carbon trans brace
custom towers from fibrelyte
j concepts hiflow body
custom red hardware
jr mg servo
- 861 Views
Last post by XLR8
- 384 Views
Last post by adam lancia
- 370 Views
Last post by juicedcoupe
- 2030 Views
Last post by bensb4
- 1361 Views
Last post by treehugger
- 1224 Views
Last post by coralguy1
- 27 Replies
- 2974 Views
Last post by GreenHell
- 1105 Views
Last post by jcwrks
