What size allen wrench?
Post Reply
dragnse7en
Post by dragnse7en »
Hello all - I'm new here, but have been into rc cars since 1984.
I'm taking apart the 6 gear tranny of an A stamp RC10, and I'm going to replace all the bushings with ball bearings. I tried to use my smallest allen wrench to take the screws out of the idler gears, but even my smallest allen wrench is too big.
What size allen wrench to do I need to get for those small screws?
Toasted Coastie
Re: What size allen wrench?
Post by Toasted Coastie »
Idler gears are still available for sale at most hobby shops. Pick up a new set, and they come with the allen wrench.....
dragnse7en
Okay - is it still part #6613, or should I need to know a different number to look for?
Toasted Coastie
ASC6614.
http://www.activepowersports.com/products/Team-Associated-%252d-BLACK-IDLER-GEARS-PR-RC10-%252d-ASC6614.html
I should have said some hobby shops. Looks like a lot are sold out....
dragnse7en
Greatly appreciated - thank you SO much :)
dragnse7en
I found enough of those AE6614s on the internet to buy, and they seem to be much, much cheaper than the 0.035 in (11/32") hex driver that I could find. I couldn't find them as hex keys. That parts bag comes with the tool I need though - that's what counts.
Thanks a million guys!
teman
Been thanked: 6 times
Post by teman »
Thanks for the info, I need one of those allen wrenches also :oops:
-Kevin
steve
Post by steve »
I think that sk has the 0-80 tap that will help save the wrench and scews , just a SMALL drop of thread lock will keep things together.
dragnse7en
steve wrote:I think that sk has the 0-80 tap that will help save the wrench and scews , just a SMALL drop of thread lock will keep things together.
Tapping a plastic part? No offense, but that makes zero sense to me. I'm going to get the black idler gears, and rebuild my trans. using the article written by Bob Gagne, and the other one written by Jim Halsey.
aconsola
Post by aconsola »
spend the money on a good wrench and you don't have to worry about the tiny hexes stripping out using the soft L-keys that come with the idler gears.
also a lot less likely to lose one of these compared to the tiny stock tool
something like this with a ground steel tip:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXYN6&P=7
dragnse7en
Yes, I already have a set a hex drivers, but they're metric. I have ordered a standard set, but that set doesn't include an 11/32" driver.
I'm very good with my parts, so I'm not worried about these small screws. I had a micro heli a couple of years back, and their screws were even smaller than the ones used on the idler gears.
Thanks though
steve
Post by steve »
give it time and you will snap a screw off. it is anal but it has paid off for me , i had a ball stud shear off in a bulkhead and was able run in a 4-40 screw and get the snapped end out the other side.
dragnse7en
steve wrote:give it time and you will snap a screw off. it is anal but it has paid off for me , i had a ball stud shear off in a bulkhead and was able run in a 4-40 screw and get the snapped end out the other side.
The only time I would use a tap for plastic, is if I'm going to use aluminum screws. Using the supplied hex wrench with the new black idler gears will be a once-time thing, so as I said, I'm not worried about it at all.
Sorry to hear about your ball stud mishap :(
Post Reply
