CA glue on NetBook screen. Any suggestions?
tim.sanderson
Post by tim.sanderson »
I accidentally got a couple of little spots of CA glue on my NetBook monitor at the track last night. :( They are pretty small (maybe 1mm each or so) but they are pretty close to the centre of the screen, and are going to drive me nuts! Any ideas on how it might be removed without damaging the plastic screen?
Has thanked: 3699 times
Been thanked: 1980 times
Re: CA glue on NetBook screen. Any suggestions?
I'd contact the manufacturer of the CA and ask them. Not sure how well it bonded, but would a careful pass with a flat razor blade do anything? I'd be very careful with that though. Or just use it as an excuse to pick up a new netbook! :mrgreen:
tim.sanderson
I was thinking more the latter. :P
I'll try contacting the manufacturer. I'm skeptical to think there would be something that is harsh enough to remove the glue, but not too harsh to damage the plastic. It's worth a shot, though!
well, either you can scrape it off with a fingernail, or you might be able to dab some acetone on it from a cloth/tissue. Anything you do will probably make the situation worse, but you can try touching an inconspicuous corner with aceton first to see if it reacts.
thats a tough one, I might just leave it alone and pick at it from time to time so it will gradually loosen....
tamiyadan
Been thanked: 6 times
Post by tamiyadan »
Chris K
Post by Chris K »
I had this happen with a small screen on a video camera - I used Losi DeBonder - it removed the glue and did NOT react with the face.
I would NOT use acetone; it's highly reactive to MANY plastics (ever had a set of wheels disapear when your were soaking the tires off?).
Certainly, anything you use (and I know you know this; just making myself feel better) be sure to spot test it and make sure that it won't react....
Hopefully you didn't glue any keys together!!!!!!! :D
Wherever you go; there you are!
mikedealer
Post by mikedealer »
try nail polish also.
Mindwarp
Post by Mindwarp »
How about this stuff? I've never used it but sounds like what you're looking for.
UN-CURE™
http://www.bsi-inc.com/Pages/hobby/accel.html
http://www.leadingedgehobbies.com/webstore/wecs.php?store=&action=display&target=BSI161
YZ-10
Post by YZ-10 »
Chris K wrote:I had this happen with a small screen on a video camera - I used Losi DeBonder - it removed the glue and did NOT react with the face.
Sounds like a good bet.
Also is it a glossy or matt screen?
Chris K
Post by Chris K »
Glossy!
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
Use debonder .
Do not freeze it, the moisture will totally ruin the CPU and motherboard when it defrosts .
Also is give time a try, the longer you leave the screen on the more heat will build up, ca glue breaks down with heat and water
Users browsing this forum: No User AvatarMojeek [Bot] and 3 guests
