Sees wheels. Tire sizes?
- askbob
- Been thanked: 4 times
What are the appropriate size tires to fit a set of sees wheels for the RC10? Preferrably a newer looking/style tire.
- romulus22
- Has thanked: 900 times
- Been thanked: 789 times
Re: Sees wheels. Tire sizes?
Also interested in this information. The set of tires that came on mine weren't glued and the rears didn't sit well at all because of the indent in the middle of the wheel.
- Brandon G
They made quite a few wheels for the RC10. First was the smaller diameter wheels designed to use the OE rubber from the short arm RC10 kits. They made a larger diameter set, 2.1" fronts, 2.0" rears. These fit pretty much all of the RC10's that used the 1/4" tapered rear axles. You can still get losi 2.0" rears in a knobby. Traxxas still sells 2.1" fronts. They look decent when combined together.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSA7378S
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ71&P=SM
The others were an on road wheel that was designed to have foams glued to them. Their diameter was pretty small though.
And of course they made truck conversion wheels for the buggies. They used 2.2" tires, any stadium truck tire can be mounted to them. The only problem with these wheels is you have to use the special barrel nut in the rear, and install the conversion axles in the front to use Tamiya Blackfoot sized wheels.
Do you have any pics of the wheels you have?
- 524 Views
Last post by Brandon G
- 4990 Views
Last post by Trackingz
- 1348 Views
Last post by Dangeruss
- 1556 Views
Last post by Bormac
- 1288 Views
- 20 Replies
- 2029 Views
Last post by tony13b
- 1333 Views
Last post by Mr. ED
- 2463 Views
Last post by aconsola
