sensored vs nonsensored
fastang
Post by fastang »
Got my Reedy BL system working finally and I now have a different question. I had a Novak system that I got wet and I assume the speed control went to hell. Im going to send it in to get fixed. Can I run the Novak *sensored* motor with the Reedy *nonsensored* speed control?
Thanks
fredswain
Re: sensored vs nonsensored
Post by fredswain »
You should be able to. It obviously just won't be sensored so that wiring harness doesn't get used.
Has thanked: 245 times
Been thanked: 342 times
No Mike, without the sensor wire attached the esc will run all that power to the first hall effect sensor and dump all that voltage into one pole of the stator causing a bad whining sound, lots of heat followed by bad smelling smoke.
fredswain
Post by fredswain »
That's good to know. I was told they'd work fine.
kaiser
Post by kaiser »
some sensored esc's have a system that will run a sensored motor if the sensor wire breaks.
hobbywing's xerun series can do this. i know it works because my sensor wire came loose during a race and i couldn't tell the difference.
not all esc's can do this though.
Most will run fine if the sensor wire comes loose, until you come to a stop or a slow section and it starts cogging. That's when you can start having trouble with most.
fastang
Post by fastang »
Thanks guys!
Will it work the other way? Sensored speed control non sensored motor?
aconsola
Post by aconsola »
no, the sensored speed control will not do anything without sensor input.
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
Charlie don't surf wrote:No Mike, without the sensor wire attached the esc will run all that power to the first hall effect sensor and dump all that voltage into one pole of the stator causing a bad whining sound, lots of heat followed by bad smelling smoke.
I don't get this :? the ESC is none sensored so why wouldn't it cycle the power to a sensored motor the same as it would to a none sensored motor?
I can understand why a sensored ESC wouldn't run a none sensored motor but I don't see why it wouldn't be ok the other way around?
Here's my TC Showroom
