Optima Mid SWB using hardcase lipos? Is it possible?
- sgirouard
So I haven't tried to completely redo everything but my hardcase lipos don't fit into the battery area.
Has anyone solved this dilemna?
- sgirouard
Re: Optima Mid SWB using hardcase lipos? Is it possible?
I ended up buying a couple softcase lipos that fit perfectly. 2S 4400 30C lipos.
I wish i could just go that route , but my track doesn't allow soft case
- Lonestar
- Has thanked: 623 times
- Been thanked: 170 times
what kind of lipos are you using, the stick-shaped ones a la Orion rocket Pack, or the "square" ones?
Paul
Paul
- sgirouard
http://www.hobbypartz.com/77p-sl4400-2s1p-30c-2222.html
These are the ones I bought for my optimas.
The only other option would be to the hardcase from what I've found (I have 3 different hardcase lipos)
- Been thanked: 325 times
Scott, I'm eventually going LiPo with my non-Mid Optimas. Those have the triangular battery brackets under the radio plate that are designed to fit rounded stick-packs. Have you found a LiPo (preferably hard-case) to fit?sgirouard wrote:The only other option would be to the hardcase from what I've found (I have 3 different hardcase lipos)
+1 on the Orion packs. I think they go up to 3600mah.
Basically, any car that old skool cells will fit into, these will too.
- Attachments
- teamorion2400lipo.jpg (13.8 KiB) Viewed 1798 times
- murphy3428
your best bet would be to just change your lower chassis to the composite craft or maybe the sassy chassy then you can use a saddle pack set up
You could always raise the top deck by 1.5mm and that shoulg give you more room to play with. Ive done that with the zxr so i can add brass weights under the lipos.
- Lonestar
unfortunately, not - they are about 1/10" longer than a true period sub-c stick pack. They will fit in MOST cars, but not all, plus you have to make sure the tubes are accessible...tsan wrote:+1 on the Orion packs. I think they go up to 3600mah.
The orion "rocket pack" sticks at least have the wires exiting properly
Paul
- ireg
For comparison
Using Orion lipo 3200 you still have space to put foam/insert to protect the battery from battery holder during rough ride.
On the other hand Orion lipo 3600 fit nicely, but space for insert will be minimal.
my apologies for the pics no time to downsize/edit as my photo editor was expired
- Lonestar
ireg wrote:For comparison
mmmh... in my memories the Orion 3200 didn't have a red sticker... or did it?
Paul
- 26 Replies
- 3657 Views
Last post by Hcp22
- 3565 Views
Last post by alcyon
- 59 Replies
- 7785 Views
Last post by j0pp3
- 2245 Views
Last post by Jerzi
- 2825 Views
Last post by Bo Wallen
- 19 Replies
- 8399 Views
Last post by lin6499
- 1797 Views
Last post by loftfind
- 52 Replies
- 12656 Views
Last post by HKS_TRD
