RC10L2 Part Question...
If you guy hadn't noticed yet, my shtick is building associated pan cars from scratch. I know I've probably pay'd 10 times the original price for a kit, but its my therapy.
Anyway, I've just about kited my next build, but I'm lacking just one part. My next project is a RC10L2 and I need everybody's help to find me a "rear chassis brace" P/N ASC8207. if any one knows if there is interchangeability between newer or older kits, please let me know.
Even if anybody has a sketch of this part, I might have to make it...
R_
R_
- Has thanked: 36 times
- Been thanked: 1318 times
Re: RC10L2 Part Question...
this place supposedly has it. wrong pic, but....
https://store.vgracing.com/asc8207-10l2-rr-chassis-brace.html
Yea, I spoke to them today, unfortunately when they check physical stock, they were out.
Thanks for the heads up...
R_
R_
I don't know enough about them so it would probably fall into the 'not quite the right part' category but I have a listing on the bay for a RC10L2O rear chassis brace part #8313.
- Been thanked: 100 times
If you look at pictures from the RC10L2 oval you will see the brace is much shorter than the one from the RC10L2 onroad.
Maybe the holes for the standoffs are the same but the bodyposts are located inwards not outwards away from the standoffs.
Of course you could make some adapterplates using two small carbon pieces.
Regarding cross braces from the older RC10LS this has different spacing between the two standoffs so the holes will be at the wrong position.
Your right, the rear brace is alot shorter, however it did match the stand off pattern and I was able to complete the build this past weekend.
It should work until I the correct part shows up, I had been waiting to build that kit for almost a year. Thanks to "lpddpd" for his part!
I'll post some pic's this week...
R_
R_
- 694 Views
Last post by blown5.0
- 855 Views
Last post by purpletimbo
- 692 Views
Last post by paul
- 657 Views
Last post by isobarik
- 596 Views
Last post by SteveK
- 682 Views
Last post by RABIDFOX50
- 189 Views
Last post by Dangeruss
- 811 Views
Last post by rooster
