TQ70 Front Tires? which car are they from
- mikedealer
i found a new set of Tq70 (pyramid pin) Front Tires and am throwing them on ebay in a little bit, what car originally do these come from? a tq10 is what i assume. I found a Used set of tq20's also im going to throw in with the lot, they are used but not mounted.
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
The long front arm tq10 is the only car I can't make any claims on since I've never seen or checked the parts of an nib one. I know the short arm tq10 has tq76 front tires and was later updated with wider arms, shock tower and other minor parts, but thought it kept the same tires? Its possible though........
- templeofspeed
Doesn't seem to be any truly definitive info out there... I'll stick with the theory until proved otherwide though. It sounds plausible, anyway...carloco8 wrote:The long front arm tq10 is the only car I can't make any claims on since I've never seen or checked the parts of an nib one. I know the short arm tq10 has tq76 front tires and was later updated with wider arms, shock tower and other minor parts, but thought it kept the same tires? Its possible though........
I did manage to archive a bunch of different TQ10 photos from auctions and around the interweb when I was doing the Dirty Girl resto.
http://www.rc10talk.com/viewtopic.php?t=1307
There was one late TQ10 new build with TQ70's on ebay a while ago, but the guy also put RPM arms & HT steering on it
I'd gladly trade NIP TQ70's or TQ71's for TQ76's just to cover my bases.
So the 2.1" front tire/car relationship seems to be:
TQ76 pin spike: TQ10 1st generation
TQ70 pyramid spike: TQ10 2nd generation (wide arm, four hole shock tower)
TQ71 three rib : Graphite Car, 6 gear CE, early production Stealth Team Cars. Basically all the "four holes per side" shock tower versions.
TQ72 four rib or TQ73 (?) five rib : Stealth CE, Stealth Team Cars.
The five rib shipped on the final versions of the CE around the time that the plastic parts were changed to black. I don't know about the final Team versions.
TQ74 four rib : Worlds Car (Proline 8015) I don't think they were ever referred to as "TQ" tires, but the AE number was 6874...sooo
Maybe if someone will confirm this info we could start a part reference sticky?
Rear tires next... ?
- templeofspeed
- templeofspeed
- carloco8
Yup, the info sounds good temple! I've never heard of tq73 fronts, but I don't doubt their existence either. I recently picked up a wide arm tq10 with tq76 tires that were gound down from street use
so mine must have been an earlier run as you stated.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180119332519
- templeofspeed
The parts books says 6873 5 rib tires, new kit standard. I maybe made up the TQ73 part...carloco8 wrote:Yup, the info sounds good temple! I've never heard of tq73 fronts, but I don't doubt their existence either. I recently picked up a wide arm tq10 with tq76 tires that were gound down from street useso mine must have been an earlier run as you stated.
Still, that's a good looking TQ10! Has the OG RC10 gear cover, even... Maybe the original owner wore out more than one set of tires...
Does it have ALL the side chassis holes countersunk?
Wouldn't it be nice if AE would provide a detailed history of the evolution? Like the VW community has...via Progressive Refinements. You'd think it wouldn't be that hard to do...
- carloco8
He definitely changed the rears....... and then wore them out too! When I got the car, it had worn out yokomo tr-8 tires in the back and tq76 fronts. It had the 4-hole front shock tower, black idler gears (I think the short arm tq10 had the white ones?) and all bushings in the back with just the four front wheel bearings (similar to what came with the short arm car). I looked at the pics of your tq10 in the dirty girl post and my chassis has all the side holes countersunk just like it.
I agree with you, I kinda wish associated had kept a tab on this "Horizon tq10" the way they did for their own. Where's the love?
- 32 Replies
- 2769 Views
Last post by MarkyDents
- 1651 Views
Last post by treehugger
- 2183 Views
Last post by klavy69
- 1277 Views
- 882 Views
- 1532 Views
Last post by Chris K
- 1065 Views
Last post by fredswain
- 755 Views
Last post by Mr. ED
