AE Reedy modified motor info.
CAT3K
Post by CAT3K »
Has anyone got any information on this motor?
I got it in a box if parts and just wanted to know what it originally came with and what wind it may be. I tried searching the forum but i couldn't find one like this.
Thanks
Paul.
tucker330
Re: AE Reedy modified motor info.
Post by tucker330 »
I had some of this era motors. They went by color, I.E. pink dot, blue dot, red dot ect. I think that the red dot was a 17 turn, the pink maybe a 15 turn.
isobarik
Been thanked: 10 times
Post by isobarik »
It should have a tiny sticker on it saying what it is....not turns but a colored sticker ie
red dot its and red dot
goldstar well you get the picture.
mvh isobarik
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
There is a list of motor winds including Reedy Modified here: http://www.rc10talk.com/viewtopic.php?f=78&t=18586 or here: http://aedownloads.com/pdf/oldMRmotors.pdf
The dot or star are those that tells You the wind. They are in can near one of the endbell closing screw under the big Reedy sticker. It seems to be there but I could not see the color of the dot from that angle.
Jirka
CAT3K
Post by CAT3K »
Thanks for the tips. I've looked where you suggested but there is only a white sticker with timing marks on it. I can't seem to find any dots or stars anywhere so maybe they've been rubbed off over the years. Thanks anyway :)
Paul.
Has thanked: 356 times
Been thanked: 470 times
Take it apart, most of the time Mike would have the windings written on the armature stack-
CAT3K
Post by CAT3K »
Charlie don't surf wrote:Take it apart, most of the time Mike would have the windings written on the armature stack-
Thanks! That solved it, i took it apart and it's marked on the stack (hand wirtten) as a 21 turn.
I'm assuming it's a hand wound motor then?
Thanks
Paul.
HWS_Losi
Post by HWS_Losi »
Are you sure it's 21, and not something else (perhaps the 1 is first, like 12 or 13 or 17 or something)? if the writing was sloppy it could maybe look like 21 if it were upside down.
just asking because 21 seems like an uncommon/unlikely wind. there was plenty of 27 turn motors (stock), plenty of 19 turn motors (outlaw stock / west coast / whatever), and the common "mod" winds typically started around 16 and would go down to 12 or 10 or so.
just curious!
Easily possible to be a 21, in 1985-1987 when that motor was being done there was no 27t Roar 91-
stock ranged from 34t and some other random turn and that was when you could "adjust" the timing via L wrench, pinion and pliers :x the lower turns like 10's-13's were more popular in the "Left Coast" because of the track types IMO
6521 21x2 Ultra Silver Dot
trkneller
Post by trkneller »
Charlie don't surf wrote:Easily possible to be a 21, in 1985-1987 when that motor was being done there was no 27t Roar 91-
I remember the "Dots" being a couple years later than '87. I still have a Yellow dot that is a 15-turn. Used it in my 10L Graphite and bought it new at the same time as the 10L.
I think that green label motor was 85-90 but I might be wrong
CAT3K
Post by CAT3K »
scr8p wrote:6521 21x2 Ultra Silver Dot
Cool thanks. I looked again and it's definately marked 21. It also has 4 wires per solder joint so a double :)
Paul.
Users browsing this forum: No User AvatarGoogle Adsense [Bot], No User AvatarMojeek [Bot] and 5 guests
