'da blue guy
'da blue guy
i started messing around with another build. mainly just mocking some things up. when it's all said and done, it'll be as blue as i can make it. i wanted a blue annodized motor plate, but i wanted to retain the 2.25 stealth. so, a little bit of modifying, and now i got one. :D
i took a b3/t3 motor plate, and drilled and tapped a couple new holes so it would mount to the 2.25 stealth. then, i cut down the rear of the tub about a 1/4" or so. it need a little bit of a bend in the back, since the motor plate is a bit shorter. so it was off to the sheetmetal break for some tweaking. a couple more holes drilled and tapped, and some dremeling, and this is what i ended up with. i still have to clearance the right outdrive and the opening for the topshaft, but so far i think it looks pretty good.
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
very nice.
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
Nice work, scr8p. I wonder if I could do the same thing with a B4 motor plate and 2.25 stealth for my A&L conversion. I'd hate to chop up a perfectly good motor plate and since the B4 plate doesn't have the integrated rear bumper, it might work. I love this place...so many ideas!
i've never really looked at a b4 motor plate. but, i don't see why it couldn't be made to work.
i've had this idea in my head for quite some time now. i just didn't have the platform to try it on. the only thing i'm worried about would be the range of gearing that would mesh up. but, i'll find out soon enough. not that it matters. i probably won't use the car anyway. :wink:
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
Very interesting, I like blue, this is going to be quite bling (hopefully) :)
Here's my TC Showroom
well, i got the chassis painted. :D
tulsa
Post by tulsa »
nice work :!: :!: :D
i see you put that chassis to good use.
tulsa wrote:i see you put that chassis to good use.
oh ya, and i'm actually gonna use this one. although, i've said that about other ones before. :roll: :lol:
if someone has a set of 2.2 blue losi dirt spec tires, or knows where to get them, i'd be interested. :)
badhoopty
Post by badhoopty »
pretty killer scr8p.
well, it's almost done. i gotta make a parts run this weekend for some bits and pieces. hopefully they have the stuff in stock. i changed my mind about dying everything blue. i like the way the white parts look with the blue chassis.
badhoopty
Post by badhoopty »
dude. WOW.
that looks funky fresh. i like the no shock spring look, you should use internal springs. :wink:
Synergy
Post by Synergy »
That looks the business Scr8p, I've always liked blue white colour schemes 8)
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
That looks really nice! 8)
mrlexan
Post by mrlexan »
Jason.... dude, that in f-ing awesome! Seriously, nice job!
bscotti
Post by bscotti »
just plain awesome
