MMS front shock tower for which vechicle?
- walfre
Got this at my LHS today.
He had them stashed away in a box and thought they were for one of the Optimas. Thanks guys!
- Been thanked: 325 times
Re: MMS front shock tower for which vechicle?
Definitely not for a normal Optima/Turbo Optima. It's not wide enough to fit across the front side-plates.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Optima mid
The straight section in the middle would not work with the lazer which has a bump for the belt on top of the gearcase
- Been thanked: 10 times
MMS headers with KL .......................Kyosho Lazer..........
mvh isobarik
mvh isobarik
LLLLLLaaaaazzzzzerrrr. I think you are supposed to file off th belt tensioner bump btw. -Jeff
There is no back/front on the mms towers left/right same same .....
mvh isobarik
mvh isobarik
- minichamps11
Definitely Lazer - same as mine here
My Tamiyaclub Showroom http://www.tamiyaclub.com/member.asp?id=23061
- Mr. ED
oops, that's right kyoshofan2 posted a picture of the matching nylon front bulkhead (=without bump) in another thread about a week ago.
I forgot about that
And they're a different width at the 4mounting screws , so no even compatible with the mid
I forgot about that
Walfre do you have a car for it ?? let me know if you want to get rid of it...
mvh Isobarik
mvh Isobarik
Iso,
you can buy a stronger version from fibre lyte for the shock tower and dyna or dyno on oople dis a remake on the zxr gearbox without the lump to give this tower a perfect fit. Ive never broken one in ten years running one and you know me, i can always find a weakness point in most things.
- 1515 Views
Last post by Chickenpuff
- 2051 Views
Last post by longboardnj
- 1715 Views
Last post by tamiyadan
- 833 Views
Last post by Joksa
- 1013 Views
Last post by Daddeo
- 1628 Views
Last post by MelvinsArmy
- 802 Views
Last post by mikedealer
- 610 Views
Last post by a01butal
