Shelf queen stand set-up's?
- THE H.P FREAK
HI!... I've got plenty of RC10's that will be finished soon and will be shelf queens. Just wondering what everybody is using for little display stands to show off their RC10's or other RC cars? I know some guys use set-up work stands, some use stands from wood, old car pistons.. etc...
Post up some pics of your stand/display set-ups, or links to display stands for out RC vehicles.
Neal.
Neal.
- Johnboy72
Re: Shelf queen stand set-up's?
I really don't have any glorified shelf queens yet. But here's what I was planning. I was going to go to Lowes or Home Depot and get some plexiglass sheets. Something with a little thickness to them. Then I was going to cut them down. We'll just say something like 4"x12". Then I was going to heat up and create two bends. When said and done, it will basically be like a C'channel. It'll be clear so that way you focus on the vehicle, not the stand.
I like the Jconcepts car stands. You can paint them to match and they are not all that expensive.
eBay ID: Nsr250_sp_repsol
- dsmith
- Been thanked: 4 times
i heard of people using spray paint caps..like you mentioned pistons..
what i was wanting to do when i get the oppotunity..is to go to a store that is closing their doors and buy their display case with a light and a lock..
- drbelleville
Get some of the McAllister Jack Stand ones, they are pretty cool looking!
http://www.mcallisterracing.com/racing/page13.html
- Erich Reichert
I use the spools from stitchers (hi volume staplers) from the printshop I work at. They're just a 6" around spool but I make a paper placard to cover the spool (where the wire used to be). I'll try to take a picture tomorrow
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
- Has thanked: 36 times
- Been thanked: 1318 times
- dsmith
i know exactly what your talking about..as i am a printerErich Reichert wrote:I use the spools from stitchers (hi volume staplers) from the printshop I work at. They're just a 6" around spool but I make a paper placard to cover the spool (where the wire used to be). I'll try to take a picture tomorrow
- bearrickster
on my offrosd cars I found some plexglass stands on Ebay from Track Side RC products. but my onroad cars I just went to walmart to the craft section and got some sticky back foam pads like the battey pads. and covered 1x2 wood scrap peices cut to the car lengh. they look good and work great. the cost was under 10bucks for over a dosen. you could do the same process with 2x4's for off road cars. just enough to keep the tires off the ground.
Hey Rick, do you have a picture of those? Sounds too easy.bearrickster wrote:on my offrosd cars I found some plexglass stands on Ebay from Track Side RC products. but my onroad cars I just went to walmart to the craft section and got some sticky back foam pads like the battey pads. and covered 1x2 wood scrap peices cut to the car lengh. they look good and work great. the cost was under 10bucks for over a dosen. you could do the same process with 2x4's for off road cars. just enough to keep the tires off the ground.
Gary
- bearrickster
hold on I will go get one!RedScampi wrote:Hey Rick, do you have a picture of those? Sounds too easy.bearrickster wrote:on my offrosd cars I found some plexglass stands on Ebay from Track Side RC products. but my onroad cars I just went to walmart to the craft section and got some sticky back foam pads like the battey pads. and covered 1x2 wood scrap peices cut to the car lengh. they look good and work great. the cost was under 10bucks for over a dosen. you could do the same process with 2x4's for off road cars. just enough to keep the tires off the ground.
- bearrickster
Ok in the craft section of Walmart they have a 4 inch thick pack of every color in the rainbow of sticky back foam. I cut the board rapped it around three sides, and cut it off with a hobby knife. then stick a peice on the ends and their you have it. I was just working on my new building bench(also in the picks) and had some scrap looked at the foam and just built it. I put the foam on so it wouldnt scrach my chassis. but then I liked how it looked so I built a few. if you make them smaller you could do the hole block in one peice.
- bearrickster
- 27 Replies
- 3174 Views
Last post by Chewbacca
- 764 Views
Last post by Der Kommissar
- 1536 Views
Last post by crusaderlyf
- 30 Replies
- 3530 Views
Last post by spider
- 1357 Views
Last post by GAMMACRUSH
- 1259 Views
Last post by JK Racing
- 19 Replies
- 3560 Views
Last post by knucklebuster
- 1172 Views
Users browsing this forum: Bing [Bot],
Chewbacca,
Mojeek [Bot] and 3 guests
