Hi there!
Does anyone know if I can use LIPO batteries with a normal TEU 101 tamiya speed controller? Any advice will be much appreciated!
Thanks!
Lipos with TEU 101 speed receiver
Re: Lipos with TEU 101 speed receiver
you can, i do, but you need a lipo cutoff or atleast an alarm.
your receiver also needs to be bec capable, most modern rec's are.
i just use an alarm and it works fine with my futaba rec.
I used to run Tamiya M-Chassis' with the teu esc. I used it with a spektrum receiver, and no alarm. If you are racing, you don't really need an alarm. You're only running the car for 5 or 6 minutes at a time... that leaves more than enough volts in the battery before you recharge.
If you are going to use it for 'bashing', running in a parking lot etc, then an alarm is a good idea. It's easy to lose track of time, and over run your battery.
- 2026 Views
Last post by XLR8
- 4193 Views
Last post by threesheds
- 2747 Views
- 2090 Views
Last post by flipwils11
- 901 Views
- 584 Views
Last post by klavy69
- 20 Replies
- 3383 Views
Last post by Mark Westerfield
- 1848 Views
Last post by DrumAnBass
