Ok i have some alloy wheels to mount on the front of an RC10, The axle size is 3/16, The wheel hole is 7/16. Anybody know were to get 3/16 X 7/16 Flanged bearings or some type of spacer to use 3/16 X 5/16 bearings.
Any help would be appreciated, Thanks
RC10 wheel bearing help
Re: RC10 wheel bearing help
are you sure they are not 11mm? 7/16" is a very odd bearing size.
either way, you could probably get a spacer that would fit in the wheel to adapt from 11mm to 5/16 and use standard associated flanged bearings. Probably HPI adapters would work, but I dunno what exactly is in their kit.
- nvxwax
I have 11mm bearings and they fit a little loose, Ill have to see if i can find some plastic adapters, i looked a little last night but had no luck lol
- 3592 Views
Last post by rctenracer
- 789 Views
Last post by RC104ever
- 440 Views
- 1066 Views
Last post by juicedcoupe
- 888 Views
- 1908 Views
Last post by 85Edinger
- 1097 Views
Last post by 501sRC10
- 1191 Views
Last post by AscotConversion
