RPM Tranny
RPM Tranny
I recently purchased this tranny http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEV49&P=7 but I have no idea what gears to put inside. Mainly what has me confused is on another post I came across it has completely diffrent internals from a stealth tranny. Any Ideas of what goes in there?
Re: RPM Tranny
http://www.rc10talk.com/viewtopic.php?f=35&t=18542
this is the post I was talking about that has me confused
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: RPM Tranny
That post if for an MIP. You have an RPM which are two completely different animals. Switch out the gears outta your rc10t/rc10 stealth and your are good to go.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: RPM Tranny
For this transmission, all you need is a complete stealth 2.25 diff, bearings, idler gear and slipper assembly. Oh and the mounting screws too.
- rc10johnny
Re: RPM Tranny
So if I use the stealth tranny to build this one, then how does it go from 2.25 to a 2.61 tranny??
- Has thanked: 36 times
- Been thanked: 1318 times
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
Re: RPM Tranny
scr8p wrote:there's less teeth on the rpm topshaft.
which by the way is a lot more aggressive on the idler gear...
also some cases are not molded equally and i have noticed that some of them will build more friction in the center and this can cause the idler teeth to strip or shatter
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Re: RPM Tranny
not unless you mod the top shaft by pressing the gears off an older B4 stealth shaft ( not the chinese one ) and re-installing the RPM gear on the B4 top shaft.
Re: RPM Tranny
Sorry to post something not completely related to the original topic.Charlie don't surf wrote:not unless you mod the top shaft by pressing the gears off an older B4 stealth shaft ( not the chinese one ) and re-installing the RPM gear on the B4 top shaft.
I just picked up a B4.1 slipper assy to add to my B3 rebuild. I'm guessing it's a Chinese one. Problems ahead?
SC10 -- FT B4.1
- 1496 Views
Last post by djacobox372
- 2527 Views
Last post by Whiskers
- 1130 Views
Last post by JUSS10
- 699 Views
Last post by Lowgear
- 1028 Views
Last post by Caine
- 973 Views
Last post by wyldbill
- 1018 Views
Last post by lt500r89
- 20 Replies
- 3257 Views
Last post by Northy
Users browsing this forum: Bing [Bot] and 5 guests
