RC10 runner/racer
RC10 runner/racer
Last night I was looking on rctech about a new semilocal track and that lead to looking at another thread about a vintage rc10 turned into a modern racer. Then I found this site and never made it to all the work I had to get done, so thanks for taking all my time.
But what this thread is really about is my brothers old RC10 that's still in the closet at home. It has the standard gold chassis (I guess it's called the a-stamp?) with the stealth transmission. I'll pick it up later when I swing by there for my mom's birthday.
I want to make a light runner that's made more for the track but that still retains a lot of the original parts. I'm not going to go completely all out update everything because I don't have the money for that, still have to pay for college.
Right now my plan goes:
Steering: The b2 bellcranks with the rc10gt servo saver arm, connected to b4 inline steering blocks in their respective 25 degree caster blocks.
Front Suspension: I think I'm going to stick with the stock front arms and shocks for now and hopefully use the "atlas" shock tower and possibly upgrade the shocks when I have money.
Rear Everything: I'm not sure here, I think if I use the Klein arms and a b4 hub I can run B44 cvd's without problem, is this true? Then again the "atlas" shock tower paired with the B4 wing mounts. Stock stealth transmission without any changes.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: RC10 runner/racer
There are several different builds going on that update the gold pan to use modern wheels/tires, with minimal change.
My personal build...
http://www.rc10talk.com/viewtopic.php?f=35&t=17552
Eau Rouge's build...
http://www.rc10talk.com/viewtopic.php?f=35&t=17844
Ruffy had a gold pan he is using to race against modern cars also here...
http://www.rc10talk.com/viewtopic.php?f=35&t=15630
I've been looking at your build, I like the black a lot. Very clean look. I read somewhere in there that if I use b3 cvd's with the RPM arms and carriers and no mods? But then wouldn't I have to use b3 wheels, so could I use the b3 cvd's with b4 axles so I can use b4 wheels?
I think I want to go towards something like Eau Rogue's build, racer with a lot of the older parts but still modern.
And I think Ruffy races at the same track I'm going to be taking this car to, should be a few vintage racers there.
- JK Racing
Looks like a fantastic start. If you use the B3 axles, then you will need to use the B2/B3 rear wheels (and bearings). The new Thunder Tiger car also uses the same rear wheel, so if you like white dish wheels, your in luck, they are available. You can use B4 front wheels (some have recommended the GT wide front axles, but I dont have them and mine fit fine). I would personally recommend getting rid of the z-bend wire for the steering and use a couple ball studs/cups.
If you want to use B4 rear wheels, you will have to do the changes that I and others have done, just swapping in the B4 axles isnt enough, the B4 wheel is a deep offset (flat face dish) where the B2/B3 wheels are a shallow offset (deep angled dish).
I really like the way Eau Rouge did his rear end set up, just open up the B4 hinge pin holes (on the stock rear carriers) and use the B44 rear CVDs. Then B4 wheels on the rear...very easy set up.
My next build will probably be the same way, easy greasy...
So people are modding the b4 rear hubs to just push the rear width out? B4 carriers with B44 cvd's sounds great, I really want to use B4 wheels because of availability and I really love the look of Rulux wheels.
- JK Racing
That is what Eau Rouge's car has. I've got my eyes on the Rulux also. I have a set of rear waiting for tires, wont be long
- JHarris
Ruffy and I will be at the asylum Sunday running our RC10's. Come by and check out the different setups. Ruffy's is completely stock. My "new" runner is all stock except wide GT axles in the front and I will have a couple there with the B4 rear carrier mods so you will have plenty to see.
- Ruffy
- Been thanked: 66 times
seth not really to push the width out, since the wheels/tires still have to be out at the same width (width established by ROAR Rules), everyone is basically working the dimensions that will work from the outermost legal width dimension inwards, and changing parts as they need so that they can run the B4 wheels that are plentiful.
Or you could do like Jeff who has found that his stock RC10 works awesome, and use the ThunderTiger rear wheels with stock RC10 tapered universals. Jeff's car was on fire last Sunday during tests, as we watched it do lap after perfect lap, jumps and acceleration all without any "mods" except on the front axles as he mentiones, so he can use the surplus of front wheels/tires he has mounted from his B4, but the width is identical to my all stock RC10 gold racer. His car will be one to watch this weekend, as it was amazing, and he drove it perfectly.
- JK Racing
The direction on my next build may have just changed...the TT wheels take the tapered axle? Fantastic news.Ruffy wrote: Jeff who has found that his stock RC10 works awesome, and use the ThunderTiger rear wheels with stock RC10 tapered universals.
Hmm, so wide front gt axles on the front. Then on the rear do the b44 cvd and b4 hubs. Then b4 wheels all around. The stock steering is good enough?
And of course upgrade the turnbuckles, which I found I have a few lunsfords sitting around and they all seem to be the exact sizes I need, lucky me.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Ball bearing steering is better and more durable and precise IMO. Other than that the rest of the buggy is pretty much good to go. Also Atlas's front and rear towers are way more durable than the stock units, and the front tower will accept the .89 threaded B4 shocks for adjustment.
That's what I was thinking. I want to do the b2 servo setup (not sure what everyone calls it on here) but I need part number 7306, I can't find anyone that seems to have it in stock.
The B2 servo saver parts are in the 9000 PN's, the GT/DS/T2 servo saver/bell cranks are in the 7000 PN's but not the one you listed- do you have a pic of what you are looking for?
- 1817 Views
Last post by badattitude
- 51 Replies
- 5740 Views
Last post by Mr. ED
- 32 Replies
- 4048 Views
Last post by fordtransman
- 952 Views
Last post by mikea96
- 1734 Views
Last post by Mad Racer
- 2028 Views
Last post by Minicooper 35
- 93 Replies
- 18520 Views
- 714 Views
Last post by blown5.0
