hot trick help please
on the rc10 arms, the kit uses small phillips head screws, what is exact replacement size. and does anyone think they make a common hex head the same size?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: hot trick help please
No phillips head screws on the arms- only 4/40 cap head screws, unless you are referring to the 8/32 phillips head screws that attach the suspension through the chassis ( and fasteners express makes steel 2.5mm hex/100 deg countersunk ) or someone put some metric Kyosho or Yokomo screws in-
- aeiou
The screws used to hold the hinge pins are 1/4" 4-40. The screws that attach the shock mount to the arm are 3/16" 4-40. There are plenty of 4-40 hex bolts you can use as replacements for the Phillips screws, although button heads would be a good choice, at least for the hinge pins.
- 3236 Views
Last post by Moggie XL
- 21 Replies
- 2136 Views
Last post by Prince Steve
- 2292 Views
Last post by ChocoTaco73
- 677 Views
Last post by tulsa
- 1390 Views
Last post by Asso_man!
- 1152 Views
Last post by treehugger
- 23 Replies
- 3938 Views
Last post by Dadio
- 1909 Views
Last post by orangemazda
