Aftermarket Optima shortened A-arms & shafts?
- Been thanked: 325 times
Okay, I've seen some aftermarket A-arms for the Optima that were extended length, for use in a monster truck application...but does anyone know if any company made shortened A-arms & shafts, for on-road use for example?
The stock Optima front wheels stick out too far and it would be cool to suck them in about a half-inch.
- highwayracer
- Been thanked: 6 times
Re: Aftermarket Optima shortened A-arms & shafts?
you can try using the touring car arms and dog bones from kyosho. I had them on my Mid when the rouring car craze was in.
Regards,
Roger
Regards,
Roger
Those would be perfect, Roger...you don't happen to have a link or part numbers, do you? I'd buy a set right here and now if I knew what to buy.highwayracer wrote:you can try using the touring car arms and dog bones from kyosho. I had them on my Mid when the rouring car craze was in.
Regards,
Roger
the kyosho TF2 stuff works there is a thread in hear somewhere to check and make sure
Paul
Paul
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
TF1 spider arms and axles will work: the whole car was basically an optima mid with narrowed suspension
which are the wider arms? I can only think of maxxum FF front arms or lazer arms all-around.
Thanks a bunch, guys! I'll check on eBay for TF1 arms & axles.
Okay I discovered there really isn't a TF-1, I found nothing but HPI radio stuff when I searched for TF-1. It looks like the first model of that car is a Kyosho PureTen EP Spider, and the name TF-2 was added to the name of a subsequent model.
Anyway, I found some U-joints for the PureTen EP Spider, but they're marked (L)...so the next question: are the joints different lengths on left & right sides? or does the (L) mean something else? Thanks again.
EDIT: Furthermore...are the joints for the GP10 the same lengths as for the EP10?
- 2508 Views
- 740 Views
- 804 Views
Last post by badhoopty
- 1267 Views
Last post by TheSpeedway
- 385 Views
Last post by klavy69
- 1506 Views
Last post by railey72
- 1084 Views
Last post by Sparbolt
- 813 Views
Last post by highwayracer
Users browsing this forum: Mojeek [Bot] and 4 guests
