Need help identifying this truck
David H
Post by David H »
I picked this up yesterday for $35 and need help to figure out what it is. Thanks for the help.
Toasted Coastie
Re: Need help identifying this truck
Post by Toasted Coastie »
Looks like a Rustler chassis to me...
skunk.werkz
Post by skunk.werkz »
yep.
David H
Post by David H »
Thank you for the help on this.
ricerscott
Post by ricerscott »
Definatly an earlier rustler, but not an early early one as yours does have the slipper clutch on it which is a plus!
David H
Post by David H »
I have been away for a little bit, could you tell me what else is needed to complete this truck.
airdreams1
Post by airdreams1 »
going to need a front batterie strap, radio, reciever, speed control, posibly a front camber link (the one with zip-ties looks to have been repaired?) battery & charger. Maby a new bodie as well. That one doesnt look like it fits all that well.
Id also recomend converting over to ball berrings if that hasnt been done yet & a RPM bumper. As things brake replace them with RPM parts (front & rear arms, caster blocks, camber links, etc.
David H
Post by David H »
airdreams1 wrote:going to need a front batterie strap, radio, reciever, speed control, posibly a front camber link (the one with zip-ties looks to have been repaired?) battery & charger. Maby a new bodie as well. That one doesnt look like it fits all that well.
Thank you for your help, this is my only electric car at the moment and I wanted to make sure I picked up everything at once. Also I have replaced the front camber link since this picture. Looks like I will be off to my local hobby shop to finish it up. Thanks again.
dandaman
Post by dandaman »
definately early rustler.i have parts laying around for this if you need.
Return to “Traxxas Forum”
