Ultima and Optima runners - what to do for wheels/tires
robf
Post by robf »
Hi all,
I am interested in getting my old ultima and turbo optima racers up and running again and would like to know what are the best options for current wheels and tires? I tried to search, but "tires" and "wheels" are apparently too generic of search terms :)
thanks,
Rob
treehugger
Re: Ultima and Optima runners - what to do for wheels/tires
Post by treehugger »
try some tamiya wheels from tower they will fit
robf
Post by robf »
Ok thanks. There seems to be lots of options. Which ones are most commonly used by forum members?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
There have been a couple threads on the same topic before.
The easiest combo in my opinion is desert gator wheels and team crp front axles with 4 5X11mm bearings. All easy to get on the net.
robf, I'm modernizing a Turbo Optima that I've had since purchasing it new as a normal Optima in the mid-80's, and hopped it up to a T.O. a year or two later. Recently, I was trying to find aftermarket wheels on eBay by doing searches with "Optima" in the search, and was getting NOWHERE. What's important to realize is that all Optimas/Ultimas have 12mm hexagonal drive "washers" (except the fronts on an Ultima). Do a search for "kyosho 12mm" or something, and you'll find DOZENS of aftermarket wheels to choose from! And they're WAY cheaper than original repros!
Check out these 2 wheel sets I just purchased from an Aussie guy...very reasonable price, and shipping was under $23. 2 sets of 4 wheels & tires for under $60...the style options are endless! These ones have a slightly higher diameter than the Turbo Optima wheels & tires, but only by 5mm or so.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=390199361414&ssPageName=STRK:MEWNX:IT
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=390217767587&ssPageName=STRK:MEWNX:IT
And here's a set I'll buy soon, too...these are gorgeous! Though the seller didn't include size specs or mounting specs, I messaged him and learned that they, too, are 12mm hex drives and similar in size to Turbo Optima wheels.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=370408477134
Mr. ED
Post by Mr. ED »
mm, that one set is for touring cars: too narrow and small diameter. Otherwise, indeed: also buggy wheels that use12mm hexes are plenty available
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
I run these rims. They look cool and are 2.2 inch aswell.
-Jason.
Still known as- bormac
Mr. ED wrote:mm, that one set is for touring cars: too narrow and small diameter. Otherwise, indeed: also buggy wheels that use12mm hexes are plenty available
Ah, that's true Mr. ED. I should mention I'm planning to pick up that set for when I use my on-road bodies. The front wheels & tires of the stock Turbo Optima are too wide, they end up looking silly sticking out past the wheel-wells of my road bodies.
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarGoogle [Bot], No User AvatarYandex [Bot] and 4 guests
