why don't 4WD mid-engined buggies use a 4th gear?
General info, Q&A.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
The tile says it all.
I wonder why the 4th gear is the hot set-up in mid-engined 2WD buggies but is unseen of in 4WD buggies
minichamps11
Re: why don't 4WD mid-engined buggies use a 4th gear?
Post by minichamps11 »
There's at least one on the market. Schumacher's CAT SX 4WD buggy has been around for a few years now and was designed with a "reversed" motor via extra gears for the same reason as mid engined 2WD's.....
Mr. ED
Post by Mr. ED »
:oops: you're right, I actually remember reading that
it's probably less of a minor issue than it is for 2wd, since the chassis doesn't care which set of wheels gets the torque loading, due to the awd.
Erich Reichert
Post by Erich Reichert »
The Cat used it for layout purposes mostly. The motor was on the wrong side and two gears puts too much strain on the drive train, especially with brushless motors these days.
minichamps11
Erich Reichert wrote:The Cat used it for layout purposes mostly. The motor was on the wrong side and two gears puts too much strain on the drive train, especially with brushless motors these days.
Erich, that's not true. I spoke with both team drivers & Phil Booth during the development of the CAT SX and it was originally conceived with a high efficiency twin belt drive train, until team drivers pointed out that with the introduction of LIPO batteries off-road buggies have more then enough duration and most drivers were adding weight to cope with the brushless motor power. At this point Schumacher decided to sacrifice powertrain efficiency & lightweight design in order to optimise weight distribution & traction gain from motor torque reaction.
If it were purely a layout decision, the battery would simply be on the right hand side with the motor on the left, as per the CAT '98......
I don't understand the comment about two gears at all.
Cheers,
Ian
