What's that called?
- Halgar
- Has thanked: 146 times
- Been thanked: 198 times
What's that called?
What is the "chaff" left over from injection molding? You know, the sharp stuff you have to trim/file off bodies and parts. I need the word and it escapes me at the moment ...
- Halgar
Re: What's that called?
It's something more like "strike" or "wane" ...
Don't you hate it when you've got a word on the tip of your tongue and you just can't quite grasp it?
- i crash cars
- Halgar
No, the plastic stuff, not what you were arrested for last weekend ...call-911 wrote:flashing?
Flashing sounds right, thanks.
- Been thanked: 4 times
So Halgars out looking to do some FLASHING oh boy evertyone put their blinders on LMAO.Don
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
While Halgar was "flashing" everyone, it was noticed that he also had a little "sprue"
Flash is the term for any excess material along a seam or mould line.
Gate trim is the part where the component is trimmed off the sprue (or the frame that holds all the moulded parts)
- Eau Rouge
- Been thanked: 5 times
Actually, the "sprue" are the mold tunnels that flow the plastic to the actual parts, not the extra bits of material around an unlclean mold. They make up essentially the bars in the plastic trees that connect the pieces in the mold. The hangnails around a molded part that need to be cleaned off with a knife or Dremel is called flashing.jwscab wrote:sprue is also the correct term.
- 1331 Views
Last post by mikedealer
- 933 Views
Last post by GeneralZod
- 921 Views
Last post by THUNDERSTRIKE1
- 547 Views
Last post by polarbear
- 775 Views
Last post by adam lancia
