First the ball cup snaps.
Second the nose tubes bend.
Third my damn a-arm breaks, right here I knew I should have threw some cheap a-arms on.
Then finally, im not sure I might have bent my nose plate.
yes. you will have to reset trim as you change cars but thats an easy fix. Just gotta bind each rx to your tx.burnsmonkey wrote:. But I did have a question, if I get a Spektrum radio all I have to do is buy tx for my cars and all my cars will work with my 1 spektrum radio?
+1. Well, sort of. I do think 2.4 is good stuff, but PCM is still very good too. I have switched to 2.4 on my cars, but I still fly PCM. And yeah, if you go PCM now you can get a sweet radio for a lot cheaper then 2.4. The best thing about 2.4 is not having crystals, but if you don't race a whole lot that doesn't even matter.Charlie don't surf wrote:Minus one for 2.4, PCM still rules, and they are dirt cheap--and I still walk up and turn on, without asking
Depends on what model you get. If you want to run several cars off one radio it would be best to have a radio with model memory for as many cars as you have. Of coarse that means getting a more expensive system because the cheaper ones don't have any model memory. If you get one with no model memory, you would have to re-bind the tx/rx, and reset all your settings for that model every time you switched to a different car, so it would basically be the same as having a crystal radio.burnsmonkey wrote:Watching some Spektrums on the bay today and seeing if I can win one for cheap. I figure if i can get one for $100 its well worth it to learn on a cheap one first. But I did have a question, if I get a Spektrum radio all I have to do is buy tx for my cars and all my cars will work with my 1 spektrum radio?
I've never heard anything bad about this one: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWPW0&P=7burnsmonkey wrote:Watching some Spektrums on the bay today and seeing if I can win one for cheap. I figure if i can get one for $100 its well worth it to learn on a cheap one first. But I did have a question, if I get a Spektrum radio all I have to do is buy tx for my cars and all my cars will work with my 1 spektrum radio?
Users browsing this forum: Ahrefs [Bot] and 3 guests
