Is this enough???
Is this enough???
I was wanting to know if this is enough parts to make a new shelf queen??
AE new parts:
8201 graphite upper brace
4347 RH aluminum bulkhead
8190 T-Bar (2)
8400 Independant front suspension kit (3)
8186 Body mounts (4)
8180 Front end screws
4335 plastic pivot socket (2)
4340 plastic washers
4114 spec springs (2)
4119 spec springs
4336 steel pivot ball (5)
6581 carbide diff balls 3/32
4350 axle bearing height adapter(3)
4345 LH plastic bulkhead
4117 spring (2)
8431 spring
3434 thrust ball bearing
3211 steering blocks
8203 lower brace spacer
8210 axle graphite
10L catalog
aftermarket parts:
Hyperdrive centerpoint steering ac501 (2)
Racers choice grade 10 ceramic diff balls and rings (2)
Racers choice ceramic diff balls
Bolink servo mount posts
Diff centering kit Cheetah Racing
Body post kit
MIP super hard shock body .510
T&A precision super diff balls
composite craft sway bay kit
Buds front wheel bearing crush sleeves (2)
Advanced diversified composites 1/2 axle shims
Buds front stress plate
Revtech body washers
Kimbrough offset rear bearing bracket
Yokomo ZC506 diff rings (4)
composite craft nylon servo mount kit
power racing products aluminum hub (L hand)
T&A precision lightweight hubs
puretech racing products battery strap
JG graphite lower brace (rear pod) (2)
composite craft brace (rear pod)
TRC hollow graphite axle for 12L
JG foam self stick body washers (2)
Technacraft 4-40 rod ends
AE 8213 diff thrust cone
Delta 1/12 front suspension springs
Kimbrough servo saver
There's also a NIP graphite chassis and what I think is a composite craft NIP 1/12 chassis.
AE new parts:
8190 T-Bar (2)
4119 spec springs
4117 spring (2)
8431 spring
8210 axle graphite
10L catalog
aftermarket parts:
Body post kit
- Has thanked: 33 times
- Been thanked: 1178 times
Re: Is this enough???
there's that new graphite 10l chassis i've been looking for..................
it would probably be enough. if not, just go buy what you need.
- scottmac74
OK
I decided I want to do a Stock Car. What chassis should I start with. I went through the parts and I have everything new to do one in graphite with all new white parts. I do not have a manual and could use one for sure.
thanks
Scott
thanks
Scott
- rc10johnny
