novak hammer pro and lipo ?
Ive got a Novak Hammer Pro in my gold pan . will I be able to run Lipo with this esc
? Thanks in advance
Re: novak hammer pro and lipo ?
you should be able to run a 2S lipo in pretty much any esc, the only problem with the lipo is you need to either make sure the esc has a lipocutoff alarm, install a small lipo alarm, or pay close attention to the cell voltage.
the reason is that the lipo cells do not like to be discharged beyond a certain point, otherwise they can become damaged or severely reduced in peformance.
great thanks . thats what I needed to knowjwscab wrote:you should be able to run a 2S lipo in pretty much any esc, the only problem with the lipo is you need to either make sure the esc has a lipocutoff alarm, install a small lipo alarm, or pay close attention to the cell voltage.
- 1257 Views
Last post by ca-rj
- 1229 Views
Last post by joel45acp
- 1749 Views
Last post by teman
- 39 Replies
- 2929 Views
Last post by slotcarrod
- 2070 Views
Last post by SoloGraphix
- 2334 Views
Last post by teman
- 837 Views
Last post by Frankentruck
- 3155 Views
Last post by wyldbill
