Bugle and my Mugen Bulldog
The place for all things Mugen.
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
Most of you here have seen Thomas's (Bugle) B34 racer. This car realy is very well designed and built by Thomas and his machining skills are the best Ive seen anybody apply to the vintage R/C scene here in Australia.
Ive been good friends with Thomas for a while now and he's always been willing to help me out on some of my vintage projects.
I aquired this Bulldog from a fellow racer and it was new built and just about never run. Sitting on a shelf in this guys garage covered in dust I grabbed the car and had it stored away for a good 6 months before starting this project.
The car was stripped down and inspected for future ideas of modification. The red ball diff pulleys were drilled out to accomodate bigger Tungsten diff balls and the rings polished to a perfect finish.
Next the hubs were to be replaced with a set of Kyosho Optima units. Innitialy it was hard to find the right length dog bones but after scouring ebay I found a set the right legth. It didnt take long before i found the front dog bones popping out on hard cornering. It was back to the drawing board. Nothing I did would prevent or stop the shafts coming out so my next thought was universals. I simply could not find the right length uni's so called on Thomas for a solution. In the end Thomas cut the uni shaft to length and fabricated a sleeve for both ends to be glued and pressed into place. These jems work a treat and have been the best solution to a nagging problem.
While the chassis was apart I added the brass steering rack that was handed to me by the late Bob Bourbage. Bob was a legendry old skool racer from the 80's and had a successful history with the Bulldog.
Now with the rack in place, uni's sorted and Optima hubs with 2.2" hex rims on board this car was looking set for the track. After a vintage meeting I found the belts to skip after a while so I have since installed a front and rear belt tensioner to keep the belts meshed to the drive teeth.
Still not completelysatisfied with the look of the disc wheels (looking too modern) I came across some Yokomo MX-4 white spoked rims. I picked up around 5 sets of these rims along with some MX-4 discs aswell. It wasn't long before I was on to Thomas yet again this time to see if he could fab some alloy wheel hubs to mount these rims to my Kyosho taper fit axles.
Then yesterday they finaly went on to my Mugen Bulldog and I couldn't be happier. I was stoked to finaly have the look I wanted and for me these rims look like they could have been designed for this car.
Thomas i just wanted to say a very public thankyou for all your help. Im chuffed to say the least. Thanks mate. :mrgreen:
-Jason.
Still known as- bormac
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Re: Bugle and my Mugen Bulldog
Post by RichieRich »
Very nice. I really like the universals. That sleeve makes them look very impressive. Great machining work on the hubs.
tiger1
Been thanked: 7 times
Post by tiger1 »
Wow, that is a great car. Those rims make the car look 21st century. :lol:
Show some more photos for us Bulldog lovers. :P
Bormac
Post by Bormac »
Thanks. I like these rims because they look a little bit like a spoked wagon wheel. Kinda vintage.
-Jason.
tiger1
Post by tiger1 »
Interesting, you thought it looks vintage but I thought it looks contemporary :lol:
Bormac
Post by Bormac »
Contemporary would be 2.2" disc type rims like B4, XXX, B44, 501X etc... I think spokes look old skool.
-Jason.
Bugle
Post by Bugle »
Definitely the best suited 2.2" rims for the car, way better than those yellow Kyosho ones!
Mad Racer
Post by Mad Racer »
Wow Jason .
That looks awsome.
Thomas your machine work is simply stunning.
A real credit to your skills and know who.
First class engineering and a Aussie. :D :D
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Definitely the most tricked out I've ever seen Jason, Kudoz to you and your friend Thomas! Have fun with that bad boy!
Come and visit the stable
tiger1
Post by tiger1 »
Bormac:
drooling over this car again today....
BTW. Which universal was that in the front?? :D
dldiaz
Has thanked: 41 times
Been thanked: 58 times
Post by dldiaz »
Wow! Awesome Bulldog!
Are you still using 4-wheel steering? Could you show some pictures of the steering set-up?
When I try to run my Bulldog at a decent ride-height (i.e. with the arms roughly parallel to the ground), the steering binds up - the L bracket to the front runs into the steering link itself...
-dldiaz
Bormac
Post by Bormac »
Not using four wheel steer just the front via a home made brass steering rack which slides back and forth through the chassis housing.
-Jason.
Return to “Mugen Forum”
