Graphite 6 Gear - No white parts were harmed....
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Post by Y'ernat Al »
...in the creation of this thread. It's started out looking something like this....(not the real car but a dead ringer stunt double)
But I got inspiration from an orphaned TQ10 motor plate. With a bag of black oxide 4-40 nuts, I came up with this...(in progress)
Image Image
The chassis bottom was well worn and scratched, but I experimented with with a coat of surfboard resin. Sanded and polished...
Image Image
Better pics to come.
- Brian -
My Gallery
treehugger
Re: Graphite 6 Gear - No white parts were harmed....
Post by treehugger »
what a cool idea did you glass it yourself ?
Y'ernat Al
treehugger wrote:what a cool idea did you glass it yourself ?
Yep. After prepping, (had a couple holes to fill and textured the unscratched smoother areas), I put tape on the underside over the factory holes. I squeegeed on a topcoat and the scratches naturally instantly disappeared. After curing, I sanded it down. Gave it a wet/sand and polish to get a good smooth reflection. Then I cleaned out the factory holes with a bit/countersink. Totally curious to run it and see how it holds up. When I flex the chassis it seems good to go. The question would be impacts from rocks and such. Based on the character of the resin around the holes where I had to re-drill and sink, the bond is impressive.
- Brian -
My Gallery
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
I think you need some Mr. Zog's Sex Wax on it now. 8)
This is all very interesting!
I've been thinking about doing this with crystal clear epoxy, yours looks great! The bond should be fantastic provided you de-greased the chassis during prep.
