rc10 steering tips???
- longboardnj
if i steer all the way in 1 direction the inner side tierods hit when i compress the shock(turn right its the right side, turn left its left side) anyway to prevent this???
- Has thanked: 36 times
- Been thanked: 1318 times
- longboardnj
Re: rc10 steering tips???
sorry...steering tie rod hits ball cup mounted to shock tower.. just wondering if anyone takes a different approach to rc10 steering... the problem is i like to run longer screws for the steering and a nut to hold the chassis together.. then i mount the steering on top of the nut.. this rises the steering and makes the problem... i usualy just run threaded rods for steering and bend them a bit to clear this to clear this...just lookin for ideas
Don't use the nut, the nose plate is threaded, just use a dab of locktite on the noseplate screws. Then use AE black ballstuds on the bellcranks and shock tower, the black ballstuds are shorter and don't interfere near as much.
These are the ballstuds http://www.amainhobbies.com/product_info.php/products_id/7980/n/Team-Associated-300-Ball-Stud-Black-6
Mark
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
from top to bottom the steering arms should look like this.
nut
steering arm
washer (if needed to prevent the steering arm from rubbing on nose plate)
nose plate
chassis
7/8" 8-32 screw
also rpm ball ends have a tendency to rub up there. the smaller stock style ball cups will give a bit more clearance.
nut
steering arm
nose plate
chassis
7/8" 8-32 screw
- longboardnj
the 3983 ball studs look like they will do the trick.. as for no nut, that does work best for steering set up.. i like to use a nut to keep the chassis from goin loose.. as far as loctite ,that does not have effect on the threads in the nose plate when you disassemble the car?? thanks for the help
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
I agree with what Mark said and just use a 'dab'. It won't affect the threads if you use the stuff that will come back apart. Different thread locking companies use different 'grades'. Some will never come back apart and some are like a medium where it will come back apart without hurting anything with a little muscle. Right now I am using a bottle of Losi threadlock-removable. Its alot like the associated stuff where it just keeps the parts from vibrating loose but comes apart easy enuf.longboardnj wrote: as far as loctite ,that does not have effect on the threads in the nose plate when you disassemble the car??
- 1067 Views
Last post by tripedaler
- 69 Replies
- 11153 Views
Last post by soniccj5
- 4332 Views
Last post by jcwrks
- 3769 Views
Last post by overscrew
- 866 Views
Last post by trek
- 1183 Views
Last post by MONSTER
- 912 Views
- 1080 Views
Last post by robindj
