MIP CVD's are driving me nuts
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
I have MIP CVD's on both my Son's and my T3's. I have a 19 turn motor and I have a 10Turn cranking out the speed. The problem is that I keep shearing the roll pins on the axles. I was out running them yesterday with my son and both our right side pins are sheared. Is there anything out there thats tougher?
- Has thanked: 36 times
- Been thanked: 1318 times
- Been thanked: 12 times
Re: MIP CVD's are driving me nuts
By roll pin I assume you are talking about the pin on the outside of the hub carrier which connects directly to the wheel.shodog wrote:I have MIP CVD's on both my Son's and my T3's. I have a 19 turn motor and I have a 10Turn cranking out the speed. The problem is that I keep shearing the roll pins on the axles. I was out running them yesterday with my son and both our right side pins are sheared. Is there anything out there thats tougher?
If that is the case then you need these:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEPF4&P=7
If you buy them from asociated it is like getting robbed, almost $1 each.
You can get steel dowel pins at places like smallparts.com for much less, under $0.10 each
http://www.smallparts.com/products/descriptions/dwx.cfm
The problem you will have with these is that they do not stay in the axle when the wheel comes off, so they are easy to lose, make sure you have fresh locknuts on the axles.
I ordered some from smallparts,com in 3/8 and 1/2" lengths, and use the longest that will fit in the wheel slot.
-Anthony
then the steel pins will do the trick.
What some have done is to use a saw/dremel to elongate the slot in the wheel and then use 1/2" long roll pins, (which can be found at most well-stocked hardware stores.)
This method is especially helpful when the broken pin has mangled the slot on the wheel as it gives a nice fresh shoulder for the longer pin to rest against.
-Anthony
-Anthony
- 482 Views
Last post by treehugger
- 1019 Views
Last post by juicedcoupe
- 700 Views
Last post by Hillbillyrcer
- 1015 Views
Last post by SRBMOJO
- 576 Views
Last post by carloco8
- 702 Views
Last post by kick
- 1224 Views
- 892 Views
