Evidently I bought the wrong parts to run 2.2 wheels
Based on a reading of the stickied "how to run 2.2 wheels" thread, I purchased the following for my gold-tub CE:
3/16 stub axles (the cvd's were discontinued and I'm fine w/ a dogbone setup):
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001191139&I=ASCC7378&P=K
And Duratrax Evader BX rear wheels:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFFG3
Unfortunately, that axle will not fit into that wheel - the axle is too thick. It's not even close... ain't gonna happen. So, what did I do wrong? What parts do I really need?
Re: Evidently I bought the wrong parts to run 2.2 wheels
Well the fit is closer than I thought. I was actually able to apply a bit of force and get the axle into the wheel, but it took a little elbow grease and its VERY tight. So, I'm thinking I can just ream out the wheel very lightly and that will be enough to make a good fit.
I'd be curious to know if others have had the same experience, for those who have tried this....
- ROH73
- Been thanked: 23 times
Yeah, they fit tight, which is not necessarily a bad thing. Just open up the holes a little bit and it should be perfect.
Regards,
Robert
Regards,
Robert
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Yes. Both the truck wheels and the buggy wheels do the same thing...very tight. I just took a drill bit that was a tad tight to get into it (like the axle is) and ran it thru and back out. Worked to loosen them up to say the least but left the others alone...some think tighter is better...strangersinspace wrote:I'd be curious to know if others have had the same experience, for those who have tried this....
- Brandon G
UM-414 wheels from Kyosho are almost an exact copy of the 3/16" B3 rear wheels. They are not made out of the brittle Duratrax plastic either.
The Kyosho America website says they're on backorder.... do you know where else to get them? Might be worth checking out. Thanks!Brandon G wrote:UM-414 wheels from Kyosho are almost an exact copy of the 3/16" B3 rear wheels. They are not made out of the brittle Duratrax plastic either.
http://www.shopkyosho.com/products/productdetail/part_number=UM414/410.0.1.1
- 740 Views
Last post by threesheds
- 568 Views
Last post by dinglem
- 1069 Views
Last post by fastang
- 1281 Views
Last post by OMC-Mikey
- 20 Replies
- 3087 Views
Last post by flipwils11
- 209 Replies
- 65207 Views
Last post by rctenracer
- 955 Views
Last post by RCveteran
- 1843 Views
Last post by bearrickster
