lipo question
lipo question
Is it safe to charge a lipo pack that is already run down some, or do I need to discharge it compleatly first? Also what is the best way to store them, and is there any maintence to do to them while in storage? Winter is coming and I'm not sure what to do to them as the lipo packs will not get much usage while there is snow on the ground.
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
Re: lipo question
Storage: If you don’t plan on using your lipo pack for longer than a week, store it at 50-60% of the pack’s rated capacity. Make sure to cycle and/or balance your packs at least once per month since leaving them on the shelf for a prolonged period of time can cause the packs to get severely out of balance or even go dead.
more can be found here
http://www.maxamps.com/lipo-care.php
Re: lipo question
So how do I do that 50% charge? The charger is a TRITON EQ. Lets say the battery is a 3c 4000mAh, do I just program the charger as if the battery is a 2000mAh? Will the charger stop at at the correct time if set up this way? I'm trying to protect my investment and there is so much info out there it is all very confuzing
Re: lipo question
Check if the charger has a storage function. If you tell it you have a 2200mah battery it'll just charge it at 2.2 amps instead. If you don't have a storage function you could fully charge it then discharge it and watch until its drained 1600mah out of it for a 4000mah battery.
Personally I just leave them with whatever charge they have after a race, or if I didn't use them on a race day leave them fully charged. Haven't had a problem. Even have a trakpower 4900 thats been sitting for about 5 months on a full charge and is still holding the full charge.
Apparently SMC's don't like to be left charged for more than a day though
- lowrydesign
Re: lipo question
use a voltmeter guys..
4.2 volts per "s"cell is full charge
3.7 volts per "s"cell is 50%
3.1 volts per "s"cell is empty
so 2x for a 2s and 3x for a 3s... and so on...
- 32 Replies
- 2574 Views
Last post by askbob
- 605 Views
Last post by delsami
- 600 Views
Last post by Diamond Dave
- 1427 Views
Last post by R6cowboy
- 34 Replies
- 3302 Views
Last post by mikedealer
- 2007 Views
Last post by THEYTOOKMYTHUMB
- 2164 Views
Last post by Brandon G
- 1921 Views
Last post by rraeford
