the "Triumph" of my "Turbo Ultima"
vin
Post by vin »
The Turbo Ultima is my first rc car...bought it back in '89 and never got to race it. in '92 I was able to get the Triumph and never got to race it too.Then for a very long time, I stopped playing. Got back in the game only 4 years ago. My kits have shown ageing especially the triumph whose rod ends have cracked and got moldy. So i tried ot make a hybrid out of it. I decided to rebuild the ultima instead of the triumph 'coz I wanted to race the ultima. I used the triumphs tranny on the ultima and was able to get um-44 arms just recently.
My objective is to rebuild both kits starting with the turbo ultima, not as a shelfer but a runner. It has been my frustration to see my turbo ultima go against other cars. The triumph perhaps would be a shelfer as it has very little scratches on its chassis.
here's a sample of the triumph's rod ends, moldy and broken...
I have ordered some other goodies from ebay....but haven't gotten the time to install it yet....
...will post pics as I progress in my rebuild.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: the "Triumph" of my "Turbo Ultima"
Post by Mr. ED »
I'm a little lost as to why you switched triumph drive train over if you're gonna restore the triumph too?
But, as long as you're having fun keep doing what you're doing. 1 car is enough to run and either should be fun especially if you can do it laid-back in a stock class.
What front wheels are those by the way?
vin
Post by vin »
I was able to get an A&L tranny for the ultima but haven't installed it yet. The triumph will get its tranny back. I just installed it on the ultima a year ago so I could run the ultima on an almost stealthy setup. I do plan to race it stock, but who knows...
The wheels are for a tamiya DT02 (I think). I know it's for a 2wd tamiya model but i can't really recall the model...bought it off ebay. The rear wheels are on 7mm negative offset which meant I needed to thicken my wheel hub. The front wheels have a bigger bearing dimension...luckily, I was able to get a bearing to fit the wheel, I think it was a 14x4mm bearing.
I will be changing the drive shaft to a cvd which would fit the ultima once I find one. I have, however, seen a tamiya cvd which is 64mm and could use the proline wheels. Would 64mm work? Will check all my items first before I proceed with rebuilding my cars.
Will post pics. Hope you guys can help me with some parts if I need any.
Mr. ED
Post by Mr. ED »
Hey Vin,
check around some of the other ultima builds, you'll find good info for example the correct lentgh CVD is 62mm: like on an ultima rb5.
Sticking with the dogbone would allow using an hpi axle which is longer and gives you the extra offset.
Look around
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarGoogle Adsense [Bot] and 6 guests
