motor help
motor help
what would be the best power plant for the 10t i picked up another one this week end and it going to be a runner
Re: motor help
Well that's a question that could get you 5000 different answers LOL
Let's start by finding out your skill level, the equipment you already have, what kind of running you will do, and also your budget.
Here is my personal preference. I'm not a speed freak, I have several cars, and I am not wild about working on or tuning motors. I would rather go with a less-expensive motor that won't be too much for less expensive batteries or speed controls, and that won't require too much maintenance.
If you were setting everything up from scratch, I would spend more money on the ESC, which will last you many, many years. Sealed endbell motors now perform pretty well, and are very inexpensive. They run from 20 turns down to the 12 turn motors that power the current Traxxas trucks. You don't really have to tune them or rebuild them or anything; just keep them clean between runs, oil the bushings, and use them until they wear out. HPI has a 15 turn motor for $14.
You can always upgrade to a better motor, a machine-wound modified motor in the 16-19 turn range is good for a truck.
Just make sure your ESC can handle the motor. I'd get a reversing ESC with a really low, or no, motor limit. That will let you use it with almost anything in the future, and you can lock-out reverse if you want to go racing.
- Erich Reichert
Re: motor help
Paw give us some details like what your electronics you have in the truck are now, where are you running the truck (if its a track how long... guessing... is the straight and is the layout tight or sweeping), also the simple stuff... are you looking for brushless or brushed, stuff like that. Tell us about you. I'm more than happy to help you out as is almost anyone else here. Shoot me a PM if you have any questions.
Re: motor help
What are your dreams, what are your ambitions? Who was your greatest influence growing up?Erich Reichert wrote:Paw give us some details like what your electronics you have in the truck are now, where are you running the truck (if its a track how long... guessing... is the straight and is the layout tight or sweeping), also the simple stuff... are you looking for brushless or brushed, stuff like that. Tell us about you. I'm more than happy to help you out as is almost anyone else here. Shoot me a PM if you have any questions.
- Erich Reichert
Re: motor help
ok... so it seems the o.p. does not remember this thread.
i picked up a very beaten 10t recently.
i put a brushless system in and fried the spur gear in 3 days.
i recommend putting a brushless system in... i used the novak gtb e.s.c. and novak 10.5
lotsa fun!
lotsa fun!
JRX2 in the late 80s... have since come to my senses with the RC10T, yes of course it's vintage! Wife is always destroying her Tamiaya LunchBox to call me her personal mechanic a few more times. Enjoying the fresh build of an RJ Speed Digger.
Re: motor help
Well, hopefully not an irradiated pinion!
It was lowest gearing possible, I think... 87T spur and 14T pinion.
I'm was gonna get a few 81T spurs from Tower and the Robinson odd size 15-25 pinion set to try a few different ratios.
At least right now, the truck is more of an asphalt burner than anything, so top speed is more fun for me.
- 1343 Views
Last post by WriteDean
- 2051 Views
Last post by uniquenamehere
- 2277 Views
Last post by MelvinsArmy
- 2337 Views
Last post by Dadio
- 3085 Views
Last post by oneyedog
- 861 Views
Last post by coxbros1
- 2166 Views
Last post by R6cowboy
- 1143 Views
Last post by treehugger
