radicator rims
- Been thanked: 81 times
radicator rims
Starting to biuld NIB a radicator kit that I have. My question is are any rims avialible to replace the pink rims in this kit. I want to keep it as original as I can but the pink rims just don't get it. I see that tower has some white rims for the trx1 . Traxxas part # are 1776 and 1774 for both front and rear they look the same but will they fit the rad.
- mrlexan
- Been thanked: 12 times
Re: radicator rims
I think the silver ones for the older bandit are still available (same as the pink, just painted silver). I see them at hobby shops all the time. I also thought the TRX3/TCP wheels (solid) where also still available.
www.gojammedia.com
www.gojammedia.com
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
Re: radicator rims
Radicator part list: http://www.traxxas.com/support/legacy/legacy_parts/Radicator-partslist.pdf
1774 will fit.... and 1775 are the fronts (I think you mistyped the 1776).
I have those on my Rad2 from Tower... they are exactly the same as the originals. Maybe a little whiter.
Jeff
Jeff
Re: radicator rims
thanks civilguy.You are correct on the type error. orderd both from tower 1774 and 1775 . thanks for the reply .
- civilguy
Re: radicator rims
No problem. Once I finish the Rad2 for VONats duty I'll post some pics. I have Losi ribs on the front and will be trying Goose Bumps on the rears-- it's great that 2.2s go right on these old Traxxas buggys. It was such a challenge finding modern rubber for the RC10 without modding the rear axles.
Best of luck!
Best of luck!
Jeff
Jeff
- murphy3428
- Prince Steve
Re: radicator rims
Is this the upgrade u might be looking for?
- Attachments
- settin03 of ebay Rad rims rms.jpg (29.69 KiB) Viewed 914 times
AKA ( settin03 R/C hobbies and more ) on Ebay
Since being on this site I have found that I have too many parts and R/C Models. Please help me get rid of them.
Re: radicator rims
I ordered these from towerhttp://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ72&P=7 and thesehttp://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ73&P=M That for the help . They are supose to be the same size as the pink kit rims . That way I can use kit tires.
- civilguy
Re: radicator rims
rctenracer- those will be the exact same as the pink kit rims, just not pink.
I have a set of original rear tires mounted (thanks JK Racing if I remember right), a set of new (Tower) original fronts mounted and a set of vintage period correct ribbed fronts (eBay) mounted.... plus a set of Losi ribbed & Goose Bumps (modern rubber) for the VONats. At under $4 a set I couldn't resist snagging a bunch of those rims from Tower.
Jeff
Jeff
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: radicator rims
Not sure if what they are made from but they dye up nicelyrctenracer wrote:Hey are the pink rad rims a that came with the kit nylon?
- 1839 Views
Last post by Top1990
- 791 Views
Last post by klavy69
- 1369 Views
Last post by Mr. ED
- 882 Views
Last post by Brandon G
- 4066 Views
Last post by tecnica2001
- 282 Views
Last post by Dangeruss
- 1270 Views
Last post by delsami
- 5580 Views
Last post by Chewbacca
