Newer Stealth Trans in Older chassis?
- Regular Member
Can I use a newer style stealth trans in the older rc10 chassis, (gold & graphite ) cars? What would be the difference as for as mounting?
- MelvinsArmy
- Been thanked: 11 times
- Sharkman
Stealth trans
VTB,As Mel said the mounting holes need to be drilled to mount a stealth trans.maybe one of the others here has the template/ fixture Associated packaged along with the Stealth trans.You could make a template out of lexan.If you have a car that came with a stealth,just cut your lexan, lay it on the stealth chassis,copy the holes and drill your chassis,plug and play!!
Dan
- Has thanked: 36 times
- Been thanked: 1318 times
- 864 Views
Last post by harvey
- 1292 Views
Last post by longboardnj
- 1935 Views
Last post by badhoopty
- 115 Replies
- 15112 Views
Last post by woodall01
- 919 Views
Last post by MarkyDents
- 2405 Views
Last post by lmw94002
- 610 Views
Last post by johnqpublic
- 24 Replies
- 4750 Views
Last post by mrlexan
Users browsing this forum: Tbot [Bot] and 4 guests
