NEW bleeder shock caps.
- mikedealer
ive been using these since 1997/8? of course they were from yokomo and those tiny screws would strip like a mother f'er if you didnt have the exact precise screwdriver tip to fit the tiny phillips.
anyway, new from associated
http://67.199.85.166/main/productdetails.php?text=6443
Re: NEW bleeder shock caps.
i use the yokomo caps and even drill out the stock caps. this was new cap was WAY over due. the bleeder screws are the way to go. before bleeder screws, i hated associated shocks. something as simple as this makes me like them a lot.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Yes. I have them on my T4. Super easy to rebuild.DHood wrote:Is it possable to use the VCS2 shock caps on the standard shocks?
RC10 old/new project underway * Losi XX4 - Heavy Metal * RC10T4 * Kyosho ZX-5 SP * BMI DB12RR
Yeah everyone around seems to be a bit too excited about this, never had any problems building shocks with normal caps. To me it just looks like another place to spring a leak..
Likewise; I've never had a problem building and bleeding Associated shocks. Though HPI/Tamiya shocks with the bladders bleed ever more easily.Bugle wrote:Yeah everyone around seems to be a bit too excited about this, never had any problems building shocks with normal caps. To me it just looks like another place to spring a leak..
I decided to convert my 10T to an SC10 a few days ago, before discovering this site, and I saw a reviewer that said he always had problems with Associated shocks. After that I pretty much took everything he wrote with a grain of salt, which pretty much involved the truck not handling at all.
- Brandon G
I've been using the Yokomo caps since running the RC10GT. I keep a Trinity micro oiler full of 30wt shock oil. When the shocks start getting some air in them (inevitable), I would simply compress the shock with it still bolted to the car, remove the screw, and stick the micro oiler tip in the hole. Fill till it starts to seep out of the hole and replace the screw. Keep the shock compressed the whole time! Comes out perfect! Can't remember the last time I rebuilt an associated shock with that cap on them...
Never leaked out of the bleeder area either.
It's about time associated came up with something like this. Losi shocks are too easy to build in comparison.
- 878 Views
Last post by mikea96
- 1406 Views
- 1360 Views
Last post by Eau Rouge
- 604 Views
Last post by Asso_man!
- 1114 Views
Last post by jcwrks
- 818 Views
Last post by HS-YZ250
- 399 Views
Last post by Retro rc
- 1035 Views
Last post by Justjoe
Users browsing this forum: Google Adsense [Bot] and 5 guests
