Have truck will bash
- arf
- Been thanked: 7 times
Somehow I "accidently" clicked the BIN button on this truck. Needs a gear cover and body.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: Have truck will bash
There are 4 T2 bodies on the same site as you found that truck--all under $20--and a couple of RPM gear covers for around $9 there for it too--, and I almost punched the same button
- arf
Is the RPM gear cover for the T2 is the same as the B2? The only ones I have found say B2/B3/T3.
- arf
Here's the ball bearing bellcrank that came with the truck. I moved the nose plate back to the position shown in the build manual (you can see the marks left from the original installation.) I don't know if I like the fact that the nuts on top of the screw posts are what tighten the noseplate to the chassis. Feels OK using the twist test but I don't know.
Could you use some thin nuts under the bell cranks to hold the nose plate tight? It would raise the cranks a bit but I don't think it would be a problem.
- Group B
It might work, but the concern would be clearance between the steering linkage tie rods, and the inner camber links rod ends.fastang wrote:Could you use some thin nuts under the bell cranks to hold the nose plate tight? It would raise the cranks a bit but I don't think it would be a problem.
Possibly a better solution would be to drill two new holes in the chassis, so as to screw the nose plate securely to the chassis in two additional locations, in the holes where the previous steering belcranks were mounted.
- arf
This is what one of our members (PUNMAXXRCFX) did with his "Ultimate T2." It solves the mounting issue but what will the extended wheelbase mean on the track?
- Attachments
- I3010005mk2.JPG.jpeg (50.5 KiB) Viewed 1119 times
- longboardnj
this is how i run the steering on my rc10t and it works great..i put nuts on the screws holding the chassis together..arf wrote:This is what one of our members (PUNMAXXRCFX) did with his "Ultimate T2." It solves the mounting issue but what will the extended wheelbase mean on the track?
- arf
- longboardnj
really why?? i ask cause i know a guy that may sell me the steering setup you have and i was thinking of buying it if the price was right.. i have my rc10t frontend set up the same way you have in pic im just using ae short steering set up (rc10gt part) http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3358&P=PU if the bb steering your using is not that great ill just stay with my set up..arf wrote:i'm gonna switch the bellcrank with the stock unit on my GT.
- arf
I think I'm correct in that the T2 and GT share a common stock bellcrank and the unit in the pix (I don't know the maker) is MEANT for the 2nd gen GT which does not use a separate nose plate. The switch is a matter of convenience.
- 903 Views
Last post by longboardnj
- 1623 Views
Last post by vintage racer
- 2161 Views
Last post by Steve71
- 1290 Views
Last post by m_vice
- 1623 Views
Last post by Dadio
- 974 Views
Last post by m_vice
- 3941 Views
Last post by SFC K
- 3367 Views
Last post by 76jimmy
