Just bought a Yokomo MR4-BC (Added pics)
- Seabass
- Business Member
- Been thanked: 12 times
Hey guys I just signed up and I am impressed with the collections some of you have. I just picked up a RTR MR4-BC off of Ebay for $129.00 (still waiting for the buggy to arrive). I have been looking up and down on the internet about this buggy but have come up empty handed. Is there any where I can go to learn more about the buggy? I appreciate any help you guys can provide. When the buggy arrives I can post pics if you guys wish.
Jake
Jake
- slotcarrod
- Been thanked: 45 times
Re: Just bought a Yokomo MR4-BC
Hi Jake, welcome to the group! For sure we all want to see pics of your sweet new Yokomo. Pics are a good thing!
Rod Littau
- Seabass
- Business Member
Hey guys the car arrived yesterday. It appears to be in really good shape. It is missing the servo but everything else is there. I noticed the front bulkhead has some glue in the mounting points for the front shock tower, but I am not sure why. I am going to tear it down and take a closer look at it. Here are the pics....
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Just bought a Yokomo MR4-BC (Added pics)
These are real fun cars: the shorter wheelbase makes them very lively and perfect for backyard and smaller club tracks.
They are somewhat low-cost versions of the MX-4 but are very strong and work well. Just make sure to replace the bushings at the wheels by bearings: you don't want to wear the axles as they'd be far more costly to replace than a set of 8 ball-bearings.
- Seabass
- Business Member
Thanks for the tip Mr Ed. I am working on stripping the body right now, man this thing is tough. I am surprised that the car has bushings in it, but I can understand since it seems to be an entry level buggy. I will definately put some bearings in the wheels. I hooked one of my Lipo packs to the car to see if it was operational and it runs fantastic. Got good acceleration and speed. I just may have to enter into the modified 4wd class at the local track soon. Any other tips or help on the car would definately be appreciated.
Jake
Jake
- Alex B
- Has thanked: 23 times
- Been thanked: 46 times
I have one in bits in my attic, i have never run it though. Mr Ed is pretty spot on with the comparison with the MX 4. The suspension and drive train are the same except for the shorter wheel base (i think the diff out drives are different), as the chassis was based on the MR4 TC (boring car). You can get a LWB conversion and a slipper for it and you could probably run newer alloy shocks, maybe first gen MR4 BX, the latter world spec ran longer shafts. Another upgrade would to replace the rear dogs with uj's.
- Mr. ED
oh yes, I would like that slipper
My MX-4 has the original slipper, but that requires a special hard to replace spur
Different diff outdrives... that would explain why I couldn't get the UJ's and dogbones of the MR4BC onto my MX4.
The MX-4 cvd's use only M3 nuts which look so fragile. so I wanted to put the MR4bc parts but then the suspension wouldn't go far enough up anymore
- Alex B
For your info Mr ED the part number for the slipper set is ZS670, but i am not 100% that will fit on the MX4 but it can still be had for around £50, pricey....
- Seabass
- Business Member
Wow, thanks for posting the link to that site. Looks like some good info there. Now another question, where in the world would I find a new body for the car? The stripping is much more difficult than what I originally thought. I have the body about 50% done and so far everything is still clear. The green paint is super tough and is not breaking loose like the blue did. I have searched up and down and have yet to find a place that has a body in stock. Most places I have found that have parts appear to be in Eropean countries. Any suggestions would be appreciated. Thanks for the help thus far.
Jake
Jake
- Mr. ED
quite a few readily available bodies should fit this car easily: tamiya plazma edge and baldre are 2 I've test-fitted and look promissing.
The chassis layout is very similar to many many later cars, so their body's fit with little trouble
- Seabass
- Business Member
Great thanks for the help on the body. Mr Ed thank you very much, I knew you guys were going to be alot of help.
- Alex B
Apparently the B44 is a good fit, quite cheap and easy to get hold of in the StatesMr. ED wrote:quite a few readily available bodies should fit this car easily: tamiya plazma edge and baldre are 2 I've test-fitted and look promissing.
yes the b44 body is a good fit i have one on mine an looks nice as far as the glue goes i havent had to do that to mine yet but i have spares so when it dose i can fix it good luck with the car hope u enjoy it like i do mine
Slingin mud baby
- 2706 Views
Last post by gmc572
- 5867 Views
Last post by 4times
- 2009 Views
Last post by stuey
- 2417 Views
Last post by WillyThickfoot
- 4679 Views
Last post by MelvinsArmy
- 21 Replies
- 2226 Views
Last post by purpletimbo
- 3546 Views
Last post by broodenburg
- 1214 Views
Last post by THEYTOOKMYTHUMB
