My 834B
- Regular Member
My 834B
Ever since the first time I saw an 834B I knew I had to have one. I had seen them come and go on Ebay (that new in box one went for a pretty penny). So I finally commited to buying one. The auction said it is a 834B RPS SE. I don't know if that is what it is though. I don't know too much about these cars. I know that this one doesn't have the stock rear tower, I think I saw a tower like this in someones Delta build. Also are these Yokomo shocks? Any other info reguarding the parts on this car would be greatly appreciated. Also I need a body for it. Did Mrlexan do a repro? What is with the bearings in the front wheels? Are they one way bearings? Oh I just bought this. I haven't got it yet, even if I did, i'm in the Air Force and deployed right now. I should be home in July, so once I get back I will be able to make some progress on this. I am going to try to do the Vintage Nats this year, being that I am going to miss the ROAR Nats. It would be cool to race 2wd and 4wd. 4wd has always been my favorite class. It's so crazy to see how much the cars have changed. I think thats why I like the 834B so much, it's just so simple.
Thanks again,
ifuonlyknew
Thanks again,
ifuonlyknew
- vintage racer
Re: My 834B
Nice score.Looking at those tyres it looks like its hardly been run.Im almost %100 that Mr lexan did a repo and I think he also did a decal set.Im sure someone else will confrim this.Its great that you plan on running it,after all that is what they were intended to do.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: My 834B
Half way down this post, there's a good concise description of the RPS by Eau Rouge.
http://www.rc10talk.com/viewtopic.php?f=29&t=2654
Although yours is a more traditional 834b, you are correct that the shocks are not standard. those are a set of Kyoshos that were originally produced for the 1/8 scales (landjump, vanning, mint las vegas and all that). Very popular for 1/10 scale hop up pre-RC10 ('84 and earlier) and probably put onto your car because the stock yokomo dampers leaked like #$%$. Those are in pretty good shape! Polish the coil overs too..those tooe are worth some attention, probably old CRP or something of that ilk.
Congrats on the pickup. I got an old yoke in 178 pieces right now as well.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Re: My 834B
It looks more like a hopped-up Wonder Dogfighter to me and definitely NOT a RPS version which had Losi tires, gold anodized rear shock tower...vintage racer wrote:Definetly an RPS,nice score.Looking at those tyres it looks like its hardly been run.Im almost %100 that Mr lexan did a repo and I think he also did a decal set.Im sure someone else will confrim this.Its great that you plan on running it,after all that is what they were intended to do.
Come and visit the stable
- vintage racer
Re: My 834B
Correct.I should make sure Im right before posting.Wouldnt the chassis be RPS being white fibreglass or is it aftermarket?A standard 834 had a black plastic chassis and centre chain guides.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: My 834B
The roll bar looks to be a decent take on the RPS one. I like how it has a bit of angle to it on the sides.
Those Kyosho shock are smooth. I have a set saved for an SRB project.
- mrlexan
- Been thanked: 12 times
Re: My 834B
Yes, I did and I still have some left.vintage racer wrote:Im almost %100 that Mr lexan did a repo and I think he also did a decal set.
www.gojammedia.com
www.gojammedia.com
- Regular Member
Re: My 834B
PM sent.mrlexan wrote:Yes, I did and I still have some left.
So Kyosho shocks. Is that a Delta rear tower? Also this car has what appears to be a Fiberglass top deck with chain tensioners. Is this a standard feature on the RPS SE or some sort of upgrade? I know alot of the 834B's I have seen have the channel for the chain to run through, i'm pretty sure they changed it to the chain tensioner to reduce drivetrain drag.
Thanks again for all the help,
ifuonlyknew
- Y'ernat Al
Re: My 834B
This post (and there are others if you search hard enough) has some Delta info...
http://www.rc10talk.com/viewtopic.php?f=29&t=3852&hilit=834b
Yes your roll bar is apears to be Delta. It's actually shown in the upper right of the Dr's first photo. As for the chain tensioner, no se here. There are other folks on this board that posess wealths of 834b wisdom (and parts). Make sure you post more pics when you open the gear box...you may have goodies in there too!
- mrlexan
Re: My 834B
Yes, the roll bar is delta. I've got one NIP so the info is good.
www.gojammedia.com
www.gojammedia.com
- Kyosho Fan
Re: My 834B
Whooow... that's a blast from the past! Those cars were the only nemisis to the early Optima crowd. Thanks for posting the pix.
- Regular Member
Re: My 834B
Cool, thanks for the info. What is up with the bearings in the front wheels? Are they one-way bearings?
- Asso_man!
Re: My 834B
yup, no diff on the frontifuonlyknew wrote:Cool, thanks for the info. What is up with the bearings in the front wheels? Are they one-way bearings?
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: My 834B
Is this actually an 834B or C? I thought the B had a single damper over the rear transmission?
- HotRodJosh
Re: My 834B
Nice score on the ol' Yokomo!
I remember my dad getting into RC racing while I was racing and an RPS SE was his choice.
It was terribly slow and inefficient, at least with a "stock" motor. But it handled pretty good.
It is on my "wish list" of cars to collect......
"I've got a fever, and the only prescription.....is more cowbell."
Pinstriping by Josh
Pinstriping by Josh
- 2548 Views
Last post by olfrjf
- 593 Views
Last post by GJW
- 1042 Views
Last post by naushad
- 1796 Views
Last post by mikea96
- 19 Replies
- 2652 Views
- 53 Replies
- 6666 Views
Last post by 59burst
- 941 Views
Last post by THEYTOOKMYTHUMB
- 49 Replies
- 7042 Views
Last post by hibernaculum
