RC10 - A Stamp Rebuild - '85 Jammin' Jay Halsey Tribute
Has thanked: 268 times
Been thanked: 2094 times
Re: RC10 - A Stamp Rebuild - Chipped Idler Gear
Dangeruss wrote: Sat May 25, 2024 7:52 pm
juicedcoupe wrote: Sat May 25, 2024 7:38 pm For my fishing reels, I make my own mix of TSI 321, Corrosion X, and 99% IPA. It's mostly alcohol as a carrier fluid.
I flood the bearings in it and let the alcohol evaporate, leaving a thin film of TSI and Cor X.
99% IPA?? How many beers in before you forget there's a bearing sloshing around the bottom of your pale ale??
Glug...Glug... :shock:
:wink:
Isopropyl alcohol, 99%.
I just use Iso-Heet, as it is 99%+ IPA, with a slight amount of ethelbenzene. Easy to find and works great.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
XLR8 wrote: Fri May 24, 2024 8:43 pm
GoMachV wrote: Fri May 24, 2024 6:05 pm ... We are running chinese $1 a pop bearings these days vs the $80 high end NMB bearings sets back in the day.
That's true and the difference is night and day.
I have some of those early metal shielded bearings and they're still smooth and spin forever.
By contrast, I've had to replace many of the modern cheap bearings from Avid - even those with rubber seals.
You get what you pay for.
I found that if you pull the rubber shields off they are good bearings underneath.
https://www.bocabearings.com/products/05-010c-ys-4689?make=TEAM%20ASSOCIATED&model=RC10
Just saying. And those probably aren't their top of the line bearings.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
JosephS wrote: Wed May 29, 2024 12:51 am
Avid balls and races look good; they appear to be accurately machined with very smooth surface finish. However, it's been my experience that when used in a dusty application, they will fail so maybe the steel Avid is using is less hard than more costly bearings.
I'm not knocking Avid since they offer a budget friendly option. I know that when I use a set in my off-road RC's, I will be replacing them at some point.
GreenBar0n
Has thanked: 1270 times
Been thanked: 860 times
Post by GreenBar0n »
Just need the 4-40 set screws to get the diff lock going, may have to order some. These are sealed bearings so they won't do a 15 second spin, $32 turned out to be the deciding factor on this :D.
I'll still do the rest of the guide steps, no hurry on this one though.
Still looking for the ESC, a Team Novak NESC-1.
Anything better in '85 than the NESC-1?
Will be pairing the ESC with a Trinity motor.
radioactivity
Has thanked: 384 times
Been thanked: 618 times
Post by radioactivity »
I like your choice of motor.
I kept 2 or 3 in my rotation of motors from mid 80's thru mid 90's.
I had better luck with the earlier 1985 version over the later version of the silver labeled 1987 Monster Horsepower stock motors.
Still have those motors today.
Chuck
GreenBar0n
radioactivity wrote: Wed May 29, 2024 10:09 pm I like your choice of motor.
Chuck
What's your favorite ESC, for the era of '85?
radioactivity
Though it was overkill for my cars and my ability, I ran the 1985 ESC-190 Pro (P) black sticker, golden letters, 6 + 2 FET.
Bought it as soon as I could afford it.
It was the only ESC I ran for probably 10 years and it still runs just like new.
Still in my Delta Spyder.
Chuck
XLR8
Post by XLR8 »
radioactivity wrote: Thu May 30, 2024 1:15 pm Though it was overkill for my cars and my ability, I ran the 1985 ESC-190 Pro (P) black sticker, golden letters, 6 + 2 FET.
Chuck
Oh my... Seeing that Spyder brings back so many memories. Tom Sagle, a fellow racer from bitd, raced Delta almost exclusively -- including their incredible 1/8 scale nitro road cars. He always brought the coolest cars to the track and was certain to qualify for A mains. I thought if I could beat Tom, I'd made it as a racer. It never happened.
Delta made some serious race cars.
Has thanked: 2604 times
Been thanked: 2977 times
Hyperdrive in that Spyder?
radioactivity
Frankentruck wrote: Thu May 30, 2024 2:05 pm Hyperdrive in that Spyder?
Yep
As quiet as a whisper in the wind.
Tried it on RC10 but it always wanted to skip teeth.
Chuck
duckhead
Has thanked: 162 times
Been thanked: 205 times
Post by duckhead »
GreenBar0n wrote: Sun May 05, 2024 4:39 pm
JosephS wrote: Sun May 05, 2024 4:17 pm The newer editions of the gears are beige.
That was for the 2013 as well as the cc release.
Does anyone know if they are sturdier than the original gears?
Would also be curious to know the answer to this.
Just catching up on this thread...
The idler gears on both the 2013 and the 2024 40th car are glass fiber filled nylon (hence the darker color) and should be much more stronger and durable than the plain nylon idler gears of days gone by...
GreenBar0n
Chuck
Thanks for the info on the Tekin, that looks like an excellent alternative to the NESC-1. Neither are inexpensive, but if they still work after all of this time, they're worth the current asking price.
1:12 on road looks like a lot of fun for racing. Really appreciate how clean yours is.
Is there a modern 1:12 car that you like these days? Would love to rebuild an old RC12L, or similar some day.
1911Colt
Has thanked: 1782 times
Been thanked: 858 times
Post by 1911Colt »
GreenBar0n wrote: Fri May 31, 2024 1:47 am
Cue the obligatory Schumacher reference from me :D
There is the current 1/12 World Champion Schumacher Eclipse 5:
https://www.racing-cars.com/rc-models-2/cars/cars-2wd-4wd=2wd/eclipse-5-1-12th-circuit-kit-k203?returnurl=%2frc-models-2%2fcars%2fcars-2wd-4wd%3d2wd%2f
JosephS
Post by JosephS »
juicedcoupe wrote: Wed May 29, 2024 1:10 am https://www.bocabearings.com/products/05-010c-ys-4689?make=TEAM%20ASSOCIATED&model=RC10
Going back in time the bearings would have been slightly above average price
Screenshot 2024-05-31 at 10.21.24 AM.png (27.19 KiB) Viewed 1695 times
I have been curious about that. Ball bearings used to be crazy expensive. I remember buying my boca bearing for $30 from them back on the day. Inflation adjusted a modern set of avid bearings would have been $8. Did something happen? Why did they get so cheap?
Users browsing this forum: No User AvatarTbot [Bot] and 3 guests
