Copy that!JK Racing wrote:Y'ernat Al, fantastic work up for a 6 gear shortie. I need to get down the SDRC and run some laps with you.
Just the Blinkinger for now. I can only deal with one at a time.JK Racing wrote:..You gonna take both the short arm and the super long arm car to see which one you like best? (to the track)
You meen consistent as a damper Reg? Yeah. Consistency is what I'm after. No additives for me thanks. I go au naturale.Charlie don't surf wrote:Closed cell has good and bad points in 1/10th- it's way more consistant as a "dampner" though- every track and setup seems to either favor it or cast it aside. If your "compounding" your tires with a traction additive though it's a must.
I got the same info JK. What I heard is that a lot of guys were taking the 1/8 red aka's and cutting them down and regluing them to fit in a 1/10 buggy rear, and they worked so awesome, that aka finally got the memo and started making them. The advantage I like is that they will last way longer, even multiple tires, unlike the open cell foams which will break down real quick under the pressures of the hi-bite clay tracks. The do have to be broken-in tho. And in the front, I heard the same..just personal preference.JK Racing wrote:thanks for "compounding" the confusion....
most tracks around me run AKA red CC inserts rear, still a mix on what to do up front. I am going all in and getting them for front/rear.
Sheldon? Is that you?Y'ernat Al wrote:I'm a scientist by trade so I'll have run my independent double blind taste tests anyway.
About ten years ago my sponsor (Modeltech UK) played around with dampers for a touring car which used discs of Closed Cell Foam in place of the traditional oil & piston + spring set-up - so it acted both as a damper & spring as one! We tried different densities of foam to achieve different levels of damping & springing - even combining muiltiple disks of different rates.Charlie don't surf wrote:Yep dampener![]()
Thank you. When we did ours, years ago...we drilled and then just CA'd a short piece of .125" brass round stock into the hole and filed off whatever was too long. Did that on both sides of the diff. I'm debating whether to do this(pin it with a set screw) to my current dirt oval racer.slotcarrod wrote:You just drill and tap for a set screw (4-40 I think) and then grind a notch in your diff rings! Measure twice, cut once!Use Locktite on the set screw and don't put it in too far that it rubs against the spur, it should be flush with the diff ring!
Users browsing this forum: Tbot [Bot] and 3 guests
