Ultima Buildup
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Ultima Buildup
That doesn't have anything to see with the slipper-clutch nor spur.
Glad you posted this pic so I can follow again.
I've never seen a topshaft like this before on an ultima: mine don't have any provision for the E-clips I see on the left side in your pic. But they all have it at the right side.
Drilling the steel axle would be out of my league, but should be do-able with the right tools.
Before you go there: did you check the shafts of the other ultima's you obtained?
Good luck
Good luck
- mikedealer
Re: Ultima Buildup
cobalt drill bit will eat through the steel like a warm knife through butter.
all the other ultimas i have, have the normal 2 pin shaft.
if you use the "final pinion" with this, it works perfectly in a ultima, but no eclip mount
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: Ultima Buildup
This slipper is the standard part for the Turbo Optima and Salute. It never came on the Ultima. But, the transmissions are pretty similar so you can swap the slipper into the Ultima.
Drilling and tapping a hole on the outer shaft sounds like a good idea. Let us know how it goes.
- Mr. ED
Re: Ultima Buildup
I'll make some pics of a shaft or 2 tonight (if I got some not mounted at least).
What do you mean by 'final pinion' ?
Re: Ultima Buildup
I took a pic of the scrap lexan that I placed to hold the bearing, it doesn't look 'trick' but it works...
Sorry for the out-of-focus blurred pic, I was in a hurry when I took it
- Attachments
- P8262267s.jpg (227.26 KiB) Viewed 1185 times
- Mr. ED
Re: Ultima Buildup
So this slipper is not the same thing as the option house part I'm thinking of then?
The one I'm thinking of is a slipper clutch built into the motorpinion.
This is also the part for which you need that brownish lexan gearcover.
If I understood well the slipper you guys are talking of sits ont he outside of the housing on the topshaft: rgiht after the spur?
Sorry for the many questions; this is total new for me and very interesting
Re: Ultima Buildup
Thats correct, as Rich mentioned it was included with the Turbo Optima and Salute (you can check the manual to see how its assembled) but since the Ultima gearbox derived from the Optima it also fits it.Mr. ED wrote: If I understood well the slipper you guys are talking of sits ont he outside of the housing on the topshaft: rgiht after the spur?
I've been running my Ultima with this setup for over a year and it really help protecting the gears. It doesn't do a very good job for traction control though, the adjustment is too sensitive.
- Mr. ED
Re: Ultima Buildup
I don't spend much on my drills; without cooling/lubricant they go blunt very fast anywaymikedealer wrote:cobalt drill bit will eat through the steel like a warm knife through butter.
Also don't have a benchpress or a good drill machine: just a dremel.
So here's how I would solve the problem you have:
The bearing at the motor side is now pushed in from the outside and stopped from falling into the housing by a small ridge.
Ream that ridge out and plug a flanged bearing from the inside. Then put shrink tube over the shaft to keep the falnged bearing from sliding into the housing.
- RichieRich
Re: Ultima Buildup
That's a clever idea. Sounds like it should work.Mr. ED wrote: So here's how I would solve the problem you have:
- mikedealer
Re: Ultima Buildup
good news, battery arrived today. fits inside perfectly with the low profile servo. doesnt even ride up on the bulkhead. mounted a couple peices of foam with shoe goo to secure it.
- mikedealer
Re: Ultima Buildup
mounted up the electronics tonight, shoe-gooed the servo down, made a custom graphite wire hold down with aluminum spacers screwed into the bulkhead, got to solder the motor still, but its lookin good
- Attachments
- P3050062.JPG (170.02 KiB) Viewed 1072 times
- P3050063.JPG (158.13 KiB) Viewed 1072 times
- P3050064.JPG (157.03 KiB) Viewed 1069 times
- P3050066.JPG (155.03 KiB) Viewed 1069 times
- P3050067.JPG (151.59 KiB) Viewed 1068 times
- mikedealer
Re: Ultima Buildup
took off those black shocks, didnt like the feel when i took for test ride. polished some beat up gold shocks, feel way better. used a couple of unknown alloy shock collars i polished
- Attachments
- P3060073.JPG (161.66 KiB) Viewed 1025 times
- P3060071.JPG (141.83 KiB) Viewed 1024 times
- P3060070.JPG (144.36 KiB) Viewed 1026 times
- P3060069.JPG (146.96 KiB) Viewed 1025 times
- Mr. ED
Re: Ultima Buildup
Have you tried putting an assodriver in the cage?
Maybe that, and a flat piece to close the top off are all you need
I'm playing with the idea for a hotshot-ultima now
- Mr. ED
Re: Ultima Buildup
Pitty the servo has to get an ear clipped to fit sideways huh. I've never used shoe-goo so don't know how strong it really is.mikedealer wrote:... shoe-gooed the servo down...
Instead I've put some extra double sided tape and sandwhished a little brace under the top-deck
- mikedealer
Re: Ultima Buildup
on a yok mx4, you used to have to cut both servo ears to mount the servo, all you needed to hold it in place FOREVER was shoe goo.. it does come off pretty easily with a flat screw driver when your done.
only downside is it takes overnight to dry
- 54 Replies
- 4761 Views
Last post by isobarik
- 785 Views
Last post by mikedealer
- 2446 Views
Last post by soniccj5
- 2870 Views
Last post by mikea96
- 1436 Views
Last post by FlyinGN
- 1836 Views
Last post by kaiser
- 26 Replies
- 2617 Views
Last post by Mad Racer
- 23 Replies
- 2783 Views
