Mike's 91 stealth build
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: Mike's 91 stealth build
Post by mikea96 »
I just got in a hurry on mine trying to get the front end done and took to much material and not evenly and they were to far off to correct.
jbmeyer13
Has thanked: 25 times
Been thanked: 11 times
Post by jbmeyer13 »
mikea96 wrote: Mon Jan 21, 2019 1:49 pm I just got in a hurry on mine trying to get the front end done and took to much material and not evenly and they were to far off to correct.
I used my father's belt sander on an older castor block (guinea pig) and made same mistake. Ended up doing the block with dremel and hand sanding. Problem with belt sander is that if you don't line up perfectly or are too aggressive it will rip right through it.
I have way more Shapeways parts than i realized; good for testing dye and grinding techniques;-)
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Certainly there's no single right way to modify a part. Usually when I have a small amount of material to remove from a small part, I'll tape a sheet of sandpaper to a flat surface (i.e. the benchtop) and run the part over the paper. This allows me to control how much material is being removed and which surface is actually touching the paper. When I try this with a belt sander it often ends in disaster and/or a trip to the medicine cabinet. :oops:
Been thanked: 3917 times
Wouldn’t it be easier to just fix the print :?: Then nobody would need to file to fit
mikea96
Post by mikea96 »
Ok got the new parts today and got one side done. Hopefully get to the other side after dinner.
mikea96
Post by mikea96 »
Ok finished the front end minus the bumper I need to cut out. This is an amazing car and has been so much fun assembling. Just waiting for final design of the steering bell cranks to be finished then I can tear down and dye the parts.
mikea96
Post by mikea96 »
Trying to decide if I should modify battery cups or leave as is. What do you guy's think?
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
modify away 8)
XLR8
Post by XLR8 »
I agree. This car was a sort of prototype model so it seems inappropriate for it to have ordinary production battery cups. Besides, you did a great job modifying the bulkhead so the cups should be easy.
mikea96
Post by mikea96 »
I agree so now I just need to decide how I want to modify them.
fredswain
Post by fredswain »
mikea96 wrote: Mon Jan 21, 2019 10:36 am They were all Fred and Justin's parts but the castor blocks were about a 1/16 of an inch wider than the arm opening.
You may have gotten an earlier revision and not the final versions. People started buying more parts so I've taken them down. Everything should fit just fine. Once I get my car done with the new bellcranks and have verified everything is correct, then I'll put them back up. I've had several variations of shapeways as they were tests for Justin and I to print.
mikea96
Post by mikea96 »
Looking forward to seeing yours Fred and being able to buy the steering to finish mine.
Lavigna
Has thanked: 1099 times
Been thanked: 1418 times
Post by Lavigna »
Great build and thread. So cool to watch it come to near completion. Thanks for all the information and photos.
mikea96
Post by mikea96 »
Thanks for the compliments! Just waiting for the steering to get done then I can tear down and dye the printed parts and do a few other mods then take care of the body and electronics.
mikea96
Post by mikea96 »
Battery strap came today thanks again Jeff!
Users browsing this forum: No User AvatarTbot [Bot] and 6 guests
