Shodog's RC10T build
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: Shodog's RC10T build
I know what your saying about the gear on the top shaft since this is the 265 conversion. The gear I used is the A-3140 NEW. iitf dropped right into the case and gear mesh is excellent. I used the very same setup on my composite Craft worlds buggy build
This one i understand, as the tops shaft I got was for stealth tranny, my question is how'd you changed the top gear of the RPM top shaft (which is smaller) and inserted the hydra shaft with the top gear of the RPM?was there a top shaft for RPM conversion for hydra? Sorry if I'm boring you guys, just that I'll be doing the same for my RC10T.
Thanks in advance,
Thanks in advance,
― Confucius
― Confucius
shodog wrote:I know what your saying about the gear on the top shaft since this is the 265 conversion. The gear I used is the A-3140 NEW. iitf dropped right into the case and gear mesh is excellent. I used the very same setup on my composite Craft worlds buggy build
Sorry, I posted before I opened your post,is this still available at tower?link would be appreciated.
Just check my parts box and saw that the one I got is the one you used,so I just need to buy the RPM conversiion tranny I 'll be set, thanks..
Thanks,
― Confucius
― Confucius
- Has thanked: 36 times
- Been thanked: 1318 times
rpm made 2 different topshafts for the 2.65 trans. one for a slipper, and one for the hydra. i think shodog might be mistaken when he says he used a losi topshaft on the truck. the a-3140 losi topshaft is for adding the hydra to a 2.25 stealth. not for the 2.65 conversion.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
I used a stealth hydra shaft, and pressed the gear off-then pressed the gear off the RPM shaft and re-installed on the hydra shaft--
If you can't find the RPM Hydra shaft
- shodog
I trimmed out the body today. it's really for an xxt and not a 10T so I'm going to run longer body mounts. It looks really good
Ah, i thought so too,scr8p wrote:rpm made 2 different topshafts for the 2.65 trans. one for a slipper, and one for the hydra. i think shodog might be mistaken when he says he used a losi topshaft on the truck. the a-3140 losi topshaft is for adding the hydra to a 2.25 stealth. not for the 2.65 conversion.
It will slip or something. Will just buy the co version first to get the clearer picture.
Thanks guys. Awesome build !!!!
― Confucius
― Confucius
- 1992 Views
Last post by asashaw
- 2090 Views
Last post by DennisM
- 84 Replies
- 24944 Views
Last post by DropDeadKustoms
- 31 Replies
- 7788 Views
Last post by shodog
- 4379 Views
Last post by RC10th
- 2634 Views
Last post by Diggley
- 47 Replies
- 7702 Views
Last post by Whiskers
- 2161 Views
Last post by Shiesty2000
