First RC10 Team, it's going to be a racer!
- Has thanked: 25 times
- Been thanked: 29 times
Re: First RC10 Team, it's going to be a racer!
Cheers Ross, I'm just building a YZ-2 so will finish this in a week or two
As for chassis stiffner I was hoping not to run one as I don't like the look of them, I haven't cut it too low so should be ok
If in doubt go flat out!
My YZ-2 is done so a little more progress!
Rear ended is nearly complete, new rear arms, arm blocks, bulkhead and gear cover
Does anyone know the part number for these long Phillips head screws??
These go through the steering bell cranks
[quote="Headling"]I cleaned up the chassis and sent it off for powder coating and made some more progress today
Gone to 12mm hex rear wheels with JC hex conversion;
May I ask what cvd's did you use for the raer hex convertion? TIA!
She is ready to race once more!
Really enjoyed the white update to the car, carried out quite a few set up changes and fresh plastics etc so looking forward to seeing how it runs next week!
So here is a running video of the car from last night, this is at Maritime Raceway in the UK
I was filming and our local hot shot A final winner was driving, he drove RC10's back in the day and really enjoyed himself
http://youtu.be/6Vh3IUt3a_Y
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Looks real good but why not attaching the ball studs/cups on the rear of the front c-hubs? Looks like you could limit the down shock travel the way it is now?
Come and visit the stable
- MatthewMoore
- Regular Member
Looking good, nice to see a tidy RC10 with the right updates.. What oil are you running? I see you're on blue front and silver rear springs.. I'm swapping from green all round to those now, Do you notice avid change in handling with the front weight? I was thinking of running one to help the balance..
Hi Matt, thanks for the comments, yes I'm really pleased with how its turned out and how well it ran on carpet
As for set up this is what I am running
Weight 30g on the front bulkhead
Lead under shorty lipo
Shocks
Front #3 pistons 600cst (42.5/45wt) Oil, Blue spring
Rear # 1 pistons 35wt losi oil, silver spring (with a coil cut off)
Long rear link, kit front
18mm ride height (I had to remove the front spring collars to get it this low)
B4 30deg caster blocks
To answer your question, yes the nose weight helped a lot for the high grip tracks, helps with low and high speed turn in, I just made my ones up from some lead sheeting and covered it in carbon tape, I used the front body mount hole to bolt the lead to the bulkhead
Good luck with your car
Shocks
Time for an update on my racer, just fitted a 50g nose weight from a guy on Oople called Slinga
Next up big bore spring conversion, Core collars are available from Schumacher Racing, I'm using Yokoko front springs and AE rear springs with B5 spring cups, pictures speak for themselves ;
- 2439 Views
Last post by factory team gair
- 2058 Views
Last post by Bholzz
- 954 Views
Last post by mikea96
- 2093 Views
- 2785 Views
Last post by RichieRich
- 716 Views
Last post by blown5.0
- 751 Views
Last post by GreenBar0n
- 979 Views
Last post by Kayne
