The next rere... a GT?!!
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Re: The next rere... a GT?!!
Not sure if this does or doesn’t help with the pullstart ideas. This one was setup like this when I picked it up a couple years back.
Hey Cru ! Go balls out
- Has thanked: 1129 times
- Been thanked: 3917 times
those look to be the pull start mounts, the non pull start dont have the raised shelf for the engine to bolt to
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Not the best photos but here's a pull start engine with non pull mounts. The only negative is that the pullstart hangs down below the chassis. The OS engines have/had big pull starts so something like a Force engine with a smaller pull start wouldn't be nearly as bad.
The header on the other hand would need to be found unless AE brings out a re-re P/S header.
Also, there is no reason you couldn't put spacers under the engine to raise it if the low hanging pullstart is a concern.
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
- ShelfRacerGT
- Regular Member
- Has thanked: 12 times
- Been thanked: 5 times
Yep. The P/S mounts are "stepped" up to raise the engine, while the non P/S ones are just "flat"...
In fact, there are a few different versions of the non P/S ones ...
...and some of them (seems to be the "early" ones) have an extra "tab" cast onto them, so they physically will not bolt up to an engine with a pull start on it..
I REALLY gotta get un-lazy, and figure out how to put pics on here!
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
ShelfRacerGT wrote: ↑Fri Jan 03, 2025 8:51 am I REALLY gotta get un-lazy, and figure out how to put pics on here!![]()
The kit appears to come with universals…does that mean 3/16 or 1/4 axles?
- Has thanked: 22 times
- Been thanked: 16 times
Love this rere! I'd have to build a Masami style with pink wheel decals and his 89 scheme.
Keep 'em comin AE!
Keep 'em comin AE!
Drivers,
Less than five... Go OnTheTone
onthetone.blogspot.com
- Garage Hack
- Has thanked: 239 times
Ah! That is pretty cool. Thanks for the links and sharing.scr8p wrote: ↑Thu Jan 02, 2025 9:04 amThe prototype is better because I built and raced it.Dangeruss wrote: ↑Thu Jan 02, 2025 1:19 amhttps://blog.jconcepts.net/2019/07/inside-look-jconcepts-rc10-egt-racing-truck/![]()
I believe only 30 kits were made and sold. I still have to build mine.
https://www.rc10talk.com/viewtopic.php?t=43125
https://blog.jconcepts.net/2018/12/inside-look-rc10egt-pro-build/
- Garage Hack
Just saw this while looking for a chassis protectorGarage Hack wrote: ↑Mon Jan 06, 2025 2:38 pmAh! That is pretty cool. Thanks for the links and sharing.scr8p wrote: ↑Thu Jan 02, 2025 9:04 amThe prototype is better because I built and raced it.Dangeruss wrote: ↑Thu Jan 02, 2025 1:19 amhttps://blog.jconcepts.net/2019/07/inside-look-jconcepts-rc10-egt-racing-truck/![]()
https://m.facebook.com/story.php?story_fbid=pfbid022BJrsrw9tMK7g8ykPxqfn8g5ok2tDHd4j5hasqWMcAozK4hKUmmpKB1FqvwWA7yBl&id=61555425271688&mibextid=Nif5oz
- Has thanked: 14 times
- Been thanked: 90 times
You guys thinking of doing box art or something different? I was never really a fan of that dark red or whatever you call it, so I'd probably at least change that color or maybe something different all together.
- RC10th
Blue looks good as a substitute for red, this is courtesy of Romulus22
- 113 Replies
- 14439 Views
Last post by Brendan2904
- 2137 Views
Last post by juicedcoupe
- 961 Views
- 2754 Views
Last post by JosephS
- 99 Replies
- 16743 Views
Last post by RogueIV
- 5320 Views
Last post by howaboutme
- 1914 Views
Last post by Dangeruss
- 38 Replies
- 7553 Views
Last post by brn2fly
