R6cowboy wrote: ↑Sun Sep 22, 2024 11:03 pmYours is NIB and does not have the small strip of black tape around the top of the can and endbell. Was the black tape not factory applied on NIB motors?radioactivity wrote: ↑Sun Sep 22, 2024 10:49 pmI think I may have the same motor that R6cowboy showed months ago.R6cowboy wrote: ↑Sun Jan 07, 2024 10:26 pm Here's a pink label Trinity Monster Horsepower 1985-87 World Champions motor I tested out today. Motor has some gahones, 38,000+ rpm at 7.2 volts.
I don't see any Trinity Monster Horsepower motors listed in the reference guide. If anyone has info/specs on these motors please share.
Label shows 12t 49,500 Rpm's
Recent find, NIB but does show some corrosion/rust from poor storage.
Chuck
Ok this is a lot all at once, lets start with. Yes Trinity Monsters are listed, there listed in 1700 Series and depending on the RPM it will help you narrow down the one you have, also if tape on endbell is intact its prob a good chance its original, also to keep in mined the 1700 series came in different turns and there was a few that had same decals, and some came in both graphite as well as aluminum endbells. The more known pink decal was RC# 1700 'NUCLEAR ASSAULT' (9 TURNS)
Highest RPM motor available. For Drag Racing or Truck Pulling (with TRINITY RC# Gear Reduction Unit) Aluminium Endbell 52,000 rpms, few years later pakaging went to blister packing and pink decal was on a few others at that pont. Same decal was done on most of there turns in black and I recall RC# 1708 'MAGIC SPEED JOEL JOHNSON
SIGNATURE' (17 TURNS]
The 1990's version of 1987 I.F.M.A.R. 2WD WORLD CHAMPIONSHIP winning motor, used by Joel "Magic' Johnson. Ultimate motor for sorted 2WD cars like JRX2, Ultima, RC10 etc. Composite Endbell
41,000 rpms. was done in green. There was also a few variations of RC 4449 *4.9 Chris Doseck™ Purple Motor Setup"
This is the latest 4.9 wet magnet motor setup that we use on our
"Chris Doseck™ World Championship Edition" modified. Everything is iricluded to build up a motor except the armature. Aluminum endbeil. Came in graphite and purple endbell as well as purple can and two types of decal one being the pink on a purple can also a signature on a purple can. So for the monster horspower motors most looked the same so best to narrow it down rpm check
