Dan's ProCat runner/racer project
Re: Dan's ProCat runner/racer project
You must have a massive stack if old Rc mags I think most of mine went in the bin along with a load of performance and fast ford when we moved house the last time
- DerbyDan
- Been thanked: 19 times
I've got one or two old RRC mags - but the scans that I've been posting are all from the same article that was posted up here in the 'scans' section (to which I posted a link in my last post)... its certainly worth a search, some interesting stuff posted in therePeakey wrote:You must have a massive stack if old Rc mags I think most of mine went in the bin along with a load of performance and fast ford when we moved house the last time
I did have loads of RRC - along with MaxPower
- DerbyDan
Forgot to add this picture... I filed the rear of the chassis to give a little more clearance for the main belt where it enters the gearbox at the rear. My new chassis measures 2.5mm in thickness where as the original is about 2.2/3mm, its only 0.2/0.3mm difference but it makes a massive difference for how stiff/rigid the chassis plate feels (not having battery slots mist help too?) - The added thickness also reduces the clearance of the belt to the U/Side of the chassis so the little chamfer at the rear should help stop the teeth of the belt from catching on the chassis edge
Found this looks like it could be a planDerbyDan wrote:Mmm interesting - that seems like an obvious solution Paul.... but doesn't it reduce the roll bar's effectiveness, being that its cross sectional area has been reduced?
- DerbyDan
Mmm - that does looks like a suitable solution... the only problem I guess is that the belt cover would need to be split to allow clearance for the 'kinked' wire? Also, i'm sure that although the wire hasn't been reduced in CSA, the bends will affect/alter the effectiveness of the roll bar.
Justin; did you see the photo showing the difference between the BossCat/ProCat eccentrics?
Yes dan I did it all makes sense now. I'm gonna stick with my trinity / wasp rear drum until I can find one of the wasp stealth gearboxes which is now high up on the want list.
I'm going to try and I stress try and get mine sorted for the revival meeting at the A1 Rc club next month. But I'm still waiting in parts to even start rebuilding mine
- DerbyDan
So I found that 6.5bl motor & put it in! Boy that made the ProCat fly! I raced the car again last night & with the car's extra speed (& punch to clear the double jump) I felt like I was much nearer the pace of the front-runners on what was a much busier race-night. I had a rather torrid time in my three qualifying runs which generally involved me moving over to let the fast guys through... who would subsquently crash... so I'd let them through again, & so-on, but I had done enough to qualify for the last spot in the 'A'. Onto the start of the A final... its sometimes better to start at the back & so it proved by picking my way past crashed cars on the first couple of corners off the start & so I found myself in 5th... the laps went by & I was really getting into the groove with the ProCat managing to stay with the field of leading cars for a short while! The two leading cars sprinted away, but having past the 4th place car (can't quite remember how) I ended up following the 3rd place car closely (A Cougar KF from memory) A couple of near grip roll moments caused me to drop back a bit but was really pleased to hold onto my 4th spot against a more competitive field!In the end I managed to finish 5th in the A final after holding 3rd for a few laps at the beginning of the race![]()
Now.... wheres my 6.5bl motor
Well done dan glad to here it went well I'm starting to get a bit exited now for when I get to take mine R
racing
racing
- Groomi
Looks like you had a good result.
Was it Astro you were racing on?
- DerbyDan
Yes I was quite pleasedGroomi wrote:Looks like you had a good result.
The track is laid out indoors on blue astro turf which gets rolled up & put away each week - so not being exposed to weather or laid over a bed of sand (like an outdoor astro turf track would be) the grip is very high!
This is the layout they did for the British Indoor champs meeting - the light blue is the astro
- DerbyDan
Moulton College Nr Northampton.... not far from Schumacher's factory
The club is SilverstoneRCMCC http://www.silverstonercmcc.co.uk/winter-masters.php
Like the look of that, proper setup we use to have a old school hall. ust before I gave up they did have a on road track built but I use to race buggies so wasn't really any use to me.
- DerbyDan
The track is less complex on a Tuesday night to the one that is shown in the photo above... to allow us to set it up & pack it away in a reasonable time, but it still is normally a good layout to challenge all levels.
Anyway, here's some photos of the ProCat in action, taken by fellow SRCMCC member Ross Whitelock,
Grip-roll!
Oops!
Grip-roll!
Oops!
- 32 Replies
- 3973 Views
Last post by fordtransman
- 1954 Views
Last post by Minicooper 35
- 1932 Views
Last post by DennisM
- 1033 Views
Last post by brian s
- 44 Replies
- 6526 Views
Last post by Peakey
- 1749 Views
Last post by badattitude
- 90 Replies
- 10299 Views
- 51 Replies
- 5617 Views
Last post by Mr. ED
